Question about Sony Playstation 3 (PS3) Console
My ps3 keeps shutting down. It is ventilated. What
My ps3 keeps shutting down. It is ventilated. Its not hot. What is the problem?
  • 281 Answers
If it is blinking a red light this is known as the yellow light of death (ironic i know). This is caused by the unit overheating causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Posted on Feb 05, 2010
How do I get my playstation 3 concole to stop over heating and shuting down?
Hello sugarplum 29,
Unfortunately with a lot of consumer electronics, especially video game consoles, the internal components and heat syncs deteriorate over time. My suggestion to you would be to make sure your console is in a well ventilated location away from anything that could be keeping heat close to it. Also, make sure the room you're playing in isn't become hot from all the heat expulsion from any electronics on, as this may cause the problem. If the problem persists, you may need to seek warranty work or a repair.
Hope this helps!
Jul 07, 2013 | Sony Playstation 3 (PS3) Console
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
My ps3 turn off by itself while Im playing a game
The auto shut-off will usually cause this because of overheating. Make sure the area around the PS3 is well ventilated and feel the PS3 right after it happens. If its really hot to the touch, try getting a cooling device.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
I have a toshiba satellite a215 s7422 and it keeps shutting down on me so i disassembled it and cleaned out the fan but it still keeps shutting down...i recently had the bios reset, i don't know if that...
You should look for the following answers.
(1) Are you operating your laptop in a in a hot and dusty environment (If yes you should know that computers do not like hot and dusty environments and they shut down to avoid a complete burn out of the machine more over the dust particles also can destroy the hardware and block internal fan ventilation ducts in between the CPU and the fan).
(2) When the your laptop PC shuts down place your hand underneath the laptop and try to feel hot spots. If you find areas unusually heated then this is the main cause of the shut down.
(3) If just after the shut down and a good usage the Laptop is cool then underneath than overheating shut down might not be the case.
If you determined that heating is the cause and you cannot change your environment than you should look for other heavy duty laptops that are robustly designed for hot environments.
I do not think that resting the BIOS can cause this.
Oct 06, 2010 | Toshiba Satellite A215-S7422 Notebook
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Shut down due to blocked ventilation
Don't block the ventilation, make sure to clean the filters, and keep it cool.
May 05, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Sony PS3 just shut off, starts to come back on and
It sounds to me as though your PS3 is overheating. Turn it off and leave it off for a day or so. Unplug all wires and keep it in an area where it will not be insulated. It needs to breath. Keep it somewhere where the hot air emanating from can escape.
Hope this helps!
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 just powered down during a game and we tried unplugging it and turning it on and off but all that happens is the red power light comes on so we turn it on. The light turns green then automatically...
Leave it to cool down and always keep your machine well ventilated. It has a protection against overheating and it will shut down by itself. Clean out the vents with compressed air then vacuum out the rest as best as you can just by sucking whatever you can out of the vent holes.
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
System shuts off after approximately five minutes of game play
Make sure your system is well ventilated and you keep the vents clean with compressed air and vacuum the vents out also, it may be overheating which means your system will shut down itself.
Laptop shuts down
My Wife's computer started doing this for about a week or two, then all it did was keep trying to boot, nothing on screen, all lights come on. Seems there is an issue with certain models of compaqs and Hp laptops. If yougo to their website and chat with a rep, you may find you have one of these models they are giving a one time free fix, even if out of warranty.
They have ours right now.
Jan 11, 2009 | Compaq Presario 700 470024-192 Notebook
Sony Playstation 3 (PS3) Console Logo
213 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
