Question about Corel WordPerfect Office 12 Home Edition (WP12ENGPCHE) for PC
SCALE FACTOR REQUIRED MAY BE TOO SMALL
When I open Wordperfect 12, a popup window tells me that "the scale factor required to show these pages (1%) may be too small to guarantee an accurate display representation". How do I change the scale factor? Since this window has been appearing, I am seeing two blank pages (instead of one) when starting a new document in Wordperfect.
4 Suggested Answers
SOURCE: Letters are printing backwards
hi pls select front and back print than take a print if u not getting than go for trobule shoting consule to ur near network experts
regards
devershi
Posted on May 16, 2008
SOURCE: When trying to sort a Wordperfect 12 document, the program closes
Backed up files, completely uninstalled Wordperfect, then reinstalled, rebooted and the problem was resolved.
Posted on Feb 18, 2009
  • 425 Answers
SOURCE: I do not want Wordperfect
This can be done with one program that is free follow this link to ccleaner. http://filehippo.com/download_ccleaner/ then you will run cleaner to get rid of history related to wordperfect, then run the registry cleaner and remove all that is selected you will have to run this a few times until nothing comes up. Then go to tools uninstall and remove any thing that has a reference to wordperfect. after you have uninstalled all they above run the cleaner and then run reg cleaner again until all the reg items are cleared. This should take care of your problem.
Posted on Jan 09, 2011
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Regular pentagon QRSTU has a side length of 12 cm and an area of about 248 square cm. Regular pentagon VWXYZ has a perimeter of 140 cm. Find the area of VWXYZ. Round to the nearest tenth.
The two pentagons are similar. If k is the scale factor for the lengths, the ratio of the areas is k^2.
Pent 1 side =12 cm
Pent 2 side =140/5 =28 cm
Scale factor (larger over smaller) is k=28/12=7/3
Area of Pent_2= (49/9)*Area of Pent_1
Your answer should be C.
Jun 29, 2014 | Office Equipment & Supplies
Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Jan 22, 2010 | Brother MFC-7820N All-In-One Laser Printer
TRYING TO INSTALL WORDPERFECT OFFICE 12 FOR FHOME USE ONLY ON MY LAPTOP. HAVE WINDOWS 7 INSTALLED. WILL NOT COMPLETE INSTALLATION. SAYS ERROR AND CLOSES OUT.
WordPerfect 12 is almost certainly incompatible with Windows 7 -- and is the reason you are getting the error message. The current version of WordPerfect is X4 -- at least 3 upgrade versions from version 12.
The drivers in version 12 were for Windows 98 / 2000. It would have worked OK with XP and maybe even Vista - but Win-7 is a new OS altogether. Sorry, but it sounds like you may need to do an upgrade.
Jan 07, 2010 | Corel WordPerfect Office 12 Home Edition...
This may sound trivial, but my husband has written a WordPerfect document and needs to add a title page at the very beginning. We can't figure out how to insert the page without messing up the whole...
Well, I don't know wordperfect very well, but if the document is going to be delivered in printed form, you could always just create a new, one-page document as your title page and print the two documents separately.
Nov 13, 2009 | Corel WordPerfect Office 12 Home Edition...
Friends computer tries to re-configure WordPerfect Office 12 on every boot. Keeps trying to find the installation disk & re- install. After cancelling many times the program runs fine, but very...
What I would advise you to do is to open the control panel and go to "Add or remove programs" for windows xp and "Programs and Features" in Windows Vista. Locate Microsoft Word Perfect and click on it. Click on "change" The next option, put a dot on the "Repair installation errors in this program...." If it asks you for the disk again. Change the path of installation file to c:\windows\system32 Hope this helps!
Jun 11, 2009 | Corel WordPerfect Office 12 Home Edition...
Wordperfect crashed in the middle of working on a document
Find the WP directory and locate the backup file. Copy it to somewhere else.
The directory will be something like WordPerfect\12\Backup with various other directories on the front of that such as c:\program files\ etc.
Open the copy and see how much of the original is present.
Michael
Reinstall WP
Open
Mar 17, 2009 | Corel WordPerfect Office 12 Standard...
Computer keeps trying to install WordPerfect Office 12
It may be in your programs that you need to uninstall WordPerfect Office 12. It just seems like something is partially installed and wants to complete.
Jan 10, 2009 | Corel WordPerfect Office 12 Standard...
Display background color
Check your MS Windows System colors
Most likely that is the cause of the problem.
Sep 29, 2008 | Corel WordPerfect Office 12 Standard...
Corel WordPerfect Office 12 Home Edition (WP12ENGPCHE) for PC Logo
93 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
