Question about Philips HTS-6500/37 System
Remote stops working
I have hts-6500 connected to the digital audiio on my set top box and a using the hdmi inputs for both set top box video out and the home theater hdmi output for viewing dvds (i have a phillps 50 inch plasma tv ) For a while all works fine, then the remote stops controling the 6500 after i turn the system off. I have to unplug the 6500 and reboot for the remote to start workin again.
  • Anonymous Dec 21, 2008
    Same thing, have to turn it on manually then remote works
  • 8,596 Answers
Both remotes are operating on the same frequency - usually you would think that having two products of same manufacturer would be a good idea, but in this case, the remotes interfere with each other.
Posted on Mar 20, 2008
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have the phillips system. i didnt get a manual with mine. so im hooking it up with out one. ok i have a cable running off of my hdmi cable and ps3 on hdmi. i took my ps3 off and pluged the blueray up to...
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
Jan 25, 2011 | Philips HTS5580W/F7 Theater System
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Amp freezes when tv channel is changed
Are you using the HDMI for video AND audio or just video? Are you using the reciever as the video switcher by routing your devices into the amp and then from the out of the amp to the TV and then back to the amp from the TV HDMI output and the digital output? You may have a loop going on and the amp can't handle it.
If you are coming out of the TV with both HDMI and digital hooked to the same input selection on the amp and have the amp set for auto signal select, it could be throwing the amp for a loop and causing it to freak. From what I can see in the specs for that amp it has 2 HDMI in for connecting a HiDef Sat/Cable box, a DVD or Blu-Ray player or a gaming console, and then 1 output to the TV. HDMI handles both audio and video. Disconnect the digital cable and just use the HDMI for both audio and video.
The optimal set up would be as follows:
With a cable or sat box with HDMI out, go to the HDMI input to the TV. From the TV use either HDMI OR digital to the amp, not both. If you have Blu-Ray or HDMI DVD, connect that to the other HDMI input on the TV.
If the TV has only 1 HDMI input then connect the Cable or Sat box to one of the amp HDMI inputs and the Blu-Ray/DVD to the other and then from the HDMI out to the HDMI in to the TV with NO audio cable from the TV to the amp. Then use the cable remote to change channels.
See if one of those connection maps works for you.
If you need more help, let me know. Include the TV model and the digital audio cable interface type, whether it is optical or coax. It would also help knowing if you are using a Satellite or Cable box and which one it is.
Cheers
Jan 03, 2009 | Yamaha HTR-6130 Receiver
Connecting my wii to my home theater
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
Nov 09, 2017 | Electronics - Others
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Philips HTS-6500/37 System Logo
153 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
