Question about ASUS Eee PC 1000H Laptop
No power/charge Plugged in AC adapter, Eee PC 1005HA will not turn on. Made sure connector is solidly in. Computer is only a few months old. Please help! Thank you
  • perpetually
    perpetually May 11, 2010
    The base of the charging jack may be solidly connected, but have you checked the post inside of the jack.
    Novelist:
  • 157 Answers
Check that the battery is properly installed. Check the AC Adapter for power. Otherwise take the machine back to the seller. It is still under warranty.
Posted on Feb 03, 2010
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
ASUS AC/DC adapter not working
Replace it, cheaper in the long run.
Mar 29, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Notebook only work on AC power. Took the battery out one day and replaced it shortly after but it wouldn't turn on. Once it was at 29% then it gradually declined as days go by. Am I doing something...
Most of the Laptop batteries damage due to the overcharging which means while battery is full work with power adapter so the battery never had a chance to drain and the cells get damaged and two hours battery afterwards works for half an hour the day by day it ends to dead - properly dispose your old battery get a compatiable or original battery for your laptop charge it for 14 hours and make sure that while your battery is full disconnect the power adapter when it goes down only and ask you to plug in that time you connect the power adapter .............
Jun 28, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When you put the charger they have light and no power
Please remove and clean the Battery terminals of the Notebook, make sure that the output pin of the AC Adapter is properly connected to the notebook. The fault might be either with the output pin of the AC Adapter or Input DC socket of the Notebook.
Mar 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire One PC Notebook
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
ASUS Eee PC 1000H Laptop Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
