Own konica Minolta 2300 dl printer. New computer has Windows 7 OS. works
  • clangood Feb 03, 2010
    tried this and it was not successful
    no it did not help
  • 1,272 Answers
Download these drivers and unzip the files to a folder.
http://64bitdrivers.com/spoof.php?id=1490
Now, perform the below steps :
1. Control Panel>Hardware and Sound>Printer>Add Printer
2. Select Local Printer not Network Printer!
3. Create new port Standard TCP/IP port, port 9100 RAW.
4. Select "Have Disk" and browse to driver downloaded and extracted to the folder above.
Hope this helps.
Posted on Feb 03, 2010
  • 10,515 Answers
To use the Magicolor with Vista 64 or Windows 7 you must have firmware release 2.85. Go to menu on printer scroll to special pages, then print configuration page. It will print a page which has your firmware version. If you need to update firmware follow these instructions carefully. Once firmware is 2.85 you can use XP X64 driver from Minolta web site. You will need to do this from an XP machine hooked to 2300DL with parallel cable on LPT1.
http://onyxftp.mykonicaminolta.com/D...&productid=993
Firmware:
ftp://ftp.printer.konicaminolta.net/pub/drivers/other/23dlfw285s.zip download and unzip this.
Procedure to Update the Firmware
Connect the Magicolor 2300 Desklaser to the PC using a parallel cable.
Do NOT reboot the PC or printer engine while code is downloading. Do NOT disconnect the power,
Ethernet or parallel cable while code is downloading. If the downloading of the code is interrupted
in ANY way, the controller board will be destroyed.
Konica Minolta Printing Solutions can not be held liable for damage as result of incorrect firmware
updates.
To upgrade the printer firmware:
1. Make sure the parallel cable is connected with PC and printer.
2. Turn on the PC, but don’t turn on the printer yet.
3. Ensure that the most recent Konica-Minolta MC2300DL printer driver is installed locally on your PC.
4. From Windows Start menu, choose Settings/Printers.
5. Right-click the printer icon or name, and then choose properties from the pop-up menu.
6. Depending on your operating system, choose either the Ports tab or the Details tab.
7. Write down the name of the port selected and the set the port to “file”.
8. Check if any other printers you may have on your system have “LPT1” selected in the Ports tab. If
so, change these ports to “file” as well.
9. Close the printer driver dialog box.
10. Turn on the printer.
Run the Paraupdate.bat
11. The firmware updating tool starts up.
The PC screen will display the following message:
press any key to continue
12. Press any key, firmware installation will start, wait until you see the message
Wait for reboot
Press any key to continue
Now, wait until the printer has rebooted completely, after this press any key. The firmware
installation continues
13. After the printer has restarted and IDLE displays in the printer’s control panel message window,
print a configuration page (Special pages/Print Config Page menu) to verify that the Controller
Firmware Version listed is v2.85s.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Feb 03, 2010
    Thanks for your response!!
    Have you checked the Instructions given by Microsoft for the Same.
    http://www.microsoft.com/windows/compati...
    Hope i helped you.
    Thanks
I just recently purchased a new computer with Windows 7 and have been unable to get the machine to recognize the printer. Will this printer work with windows 7 machines
Go to Konica web site and see if they have install software for 7. Not all printers and less scanners work with 7. Many printers work poorly if installed plug and play. Better success with manufacturers install program and follow EXACTLY the install directions.
Oct 09, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Windows 7 driver not available fro 2300 dl printer. Any suggestions. No download including vista driver works
hi after browsing all over for this i found a driver that should run your printer on windows 7 im not sure how well it will run but it should work until a better driver is available.
http://download.cnet.com/KONICA-MINOLTA-mc2300DL-unidrv/3000-2116_4-155139.html
hope this works for you ,
regards dave, please rate
Feb 03, 2010 | Konica Minolta magicolor 2300DL Laser...
KONICA MINOLTA MAGICOLOR 2300 DL
hy...you just posted a comment on my profile but i do not understand's what is your problem?if your english is not the best why did you sad to me?do you think i'm very curious about that?
Jan 10, 2010 | Konica Minolta magicolor 2300DL Laser...
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
Need driver of magicolor 2300dl to computer 64 process
I have no idea what operating system you have so go to this website and read all information as posted before downloading the driver as needed
http://www.vistax64.com/drivers/102031-minolta-magicolor-2300-dl-printer-driver.html
Nov 14, 2009 | Konica Minolta magicolor 2300DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2300 DL
Just sent you the manual.
Regards
Wayne
Oct 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
