Question about Acer Computers & Internet
Shut down when using laptop
After being online for about 40 minutes laptop shut down and restart itself.
  • 712 Answers
Pull the memory stick(s) out of the motherboard and run a single 1x512 in the top slot (under the keyboard) as well as remove the bottom cardslot device as the motherboard had a short causing this on the bottom half (where heat builds up). With these limits (max 512mb and no bottom cardslot usage). It will work great now.
Posted on Feb 03, 2010
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
Generac gp6500 will not stay running for more than 20 minutes.It shuts itself down then it is hard to restart and when it does start it will not continue to run. If I let it sit for 20 min. or more it will...
Here is support product lookup. Requires more specific numbers about your gp6500.
Shuts down automatically from oil shortage.
Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Jun 07, 2017 | Generac 5623 GP Series GP6500 8,000 Watt...
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
My laptop swithces off itself every 40 minutes
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
Sep 29, 2009 | CMB T43 750 Notebook
Unit powers itself down
does it do this when on battery mode?
or when its plugged in?
i found they do tend to drain quicker the older it gets and that just because of a week internal battery.. i just leave mine plugged in to the cig lighter in my car and i dont have that problem but if you have to use battery power it will drain fast no real fix unless you get a new internal battery and its much easier to just leave it plugged in.
May 22, 2009 | Garmin GPSMAP 172C GPS Receiver
Shuts itself down
helo,, you must change the power supply,, it has the problem
Mar 28, 2009 | Computers & Internet
T20 Laptop will turn it self off
Failing or clogged fan fan is a good possibility. Fans are cheap on ebay for those and easy to install (2 screws underneath the laptop to remove the keyboard and 3 for the fan assembly itself. I would pull the keyboard and check for dust then replace the fan if that doesnt help.
Dissasembly guide for t20-t23 is online here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-4UYM3F.html
Jan 10, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
