Question about Refrigerators
Freezer door opens when fridge door is shut
We have a two door LG refrigerator, Model No GN422FW. When we shut the fridge door the freezer door opens up. We have had the refrigerator for 2 years and it has only just started doing this. Any ideas? we have an extended warranty but have been told that if it's a design flaw then we will have to pay an $80 service charge + $90 per hour service + parts.
  • 1,531 Answers
This is a typical occurance with these unit it has alot lot do do with the the air volume in the fridge and some times how fast the doors are being closed there is no place for the air to escape so it is pushed throught the freezer compartment.
you can try and clean out your drain holes to your drain pan this will give the air a place to go.even if it a design flaw it sould not cost you any money,because it would be a factory defect and the manufacture would replace the unit.this is something that may go away all by itself
Posted on Feb 03, 2010
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
LG fridge/freezer rumbling/vibrating sound
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Jun 24, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
My LG freezer is cooling while the refrigerator doesnt.
OK THEN FROM WHAT YOU SAY SINCE THE FREZER WORKS BUT NO FRIDGE IT SOUNDS LIKE A DOOR SEAL FOR THE FRIDGE DOOR GONE BAD,DIRTY,WARPED,OR WORN OR THE DOOR IS'NT SHUTTING ALL THE WAY THIS IS THE NEXT STEP OF WHAT TO LOOK AT
Apr 12, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
Refrigerators Logo
196 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
