Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
There is a triangle with an expulmation point in it and a bulb. The tv turns on but the picture won't come on
  • 69 Answers
Have you replaced the lamp?
Posted on Feb 07, 2010
My Samsung SP50L 7HX doesn't come on keeps going on standvy and then get warning triangle with a bulb, Hear sound for a second and then it goes to standy again. Will a new bulb solve it or should i call out an engineer. \
Posted on Jun 23, 2011
2 Suggested Answers
nvdlpsvc
  • 53 Answers
SOURCE: there is a triangle with an expulmation point in
probably time to change your lamp. or nearing the end of the lamp life
Posted on Mar 18, 2010
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Mar 17, 2010 | Samsung HLP5085W 50" Rear Projection...
50" Samsung DLP TV turns on get sound and picture for 1-2 sec then goes to standby
new bulbs can leak on your pc board if not installed correctly and the fluid starts to short things out... triggers the error message.
remember always check the last thing you did before having problems.
Jan 11, 2008 | Samsung DLP HL-P5663W 56" TV
TV keeps cutting off and won't show a picture. There is a symbol I don't understand...
have a tech check your tv the problem is in the power supply or related circuit.good luck.
Apr 18, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
703 people viewed this question
Henry  Thomas
Henry Thomas
