Question about Dell Latitude D810 PC Notebook
I have a dark screen with ac cable plugged in, when I unplug from back of laptop screen brightens back up like normal. What wrong? I also have a light on at top of laptop looks light the #9 within a lock> Any idea what that is?
    Scholar:
  • 73 Answers
Your first step:.it sounds to me like your power settings for your AC go into control panel click on power options and check that your ac power profile has the brightness turned up enough , try pressing default configuration this should put it to normal, let me know if this works.
hope this works
Posted on Feb 03, 2010
Replaced screen still black but you can see something in the backround
Then you have a faulty Power Inverter.. You need to replace the power inverter below the screen... it is the Long rectangular Circuit board - it is what the lcd wires/plug plugs into.. it converts the DC power going through your laptop back to AC Power to Be able to power the bulb..They average $12 to $30 on Ebay for replacement... just unplug from both ends ( display cable plug and lcd bulb plug ) When Searching on Ebay... type : sony vaio vgn-tx power inverter
Oct 06, 2010 | Sony VAIO VGN-TXN15P/B Notebook
My presario us 700 screens comes on but the screen is dark ie will not brighten up what can i do
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 29, 2010 | Computers & Internet
My IBM Thinkpad screen has gone dark but I can still see a bit. Is there a key to brighten the screen?
Aug 29, 2010 | IBM ThinkPad T23 2647 Notebook
Laptop screen is dark can not brighten
1)TAKE OUT YOUR LAPTOP BATTERY
2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
Jan 04, 2010 | Dell Inspiron 6000 Notebook
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Jul 22, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
X205-S9359 Display going dark
while on battery right click on the desktop and then properties check your power saving options you may have a wrong setting for how it should behave on mains power... could have accidently set it to turn off display to save energy
Oct 20, 2008 | Toshiba Satellite X205-S9349 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
What key do I use to brighten up my screen while using the plug in. my screen is too dark and it is hard to see.
Try holding the "FN" key while tapping the "F10" key. If memory serves me correctly that will brighten the display on some laptops.
Good luck.
Feb 24, 2008 | Compaq Presario M2000 Notebook
Dell Latitude D810 PC Notebook Logo
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
