Question about GE Washing Machines
My whirlpool gold dishwasher makes a loud humming sound the entire loooong time it runs
  • 254 Answers
Possibly a bad bearing in the pump motor assembly,, most had a five yr parts warranty of out of warranty the parts usually run 100-300 dollars
Posted on Feb 03, 2010
Hear a humming sound when the dishwasher turned on. The panel seems to be ok. Model is GU1500'
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The soap tray will not open durring a cleaning cycle. Before this it was making a loud humming noise. it sounded like metal on metal.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 30, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Water not spraying
sounds like a bad motor, you can get a complete replacement of the motor and sump assembly for about $150-175. one piece includes new motor and chopper assemblies, less then a hour to change.
Feb 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GU2400
Yes I have a similar problem... GU2455XTSQ3 whirlpool gold. Hangs up at 52 minutes accompanied by a loud humming that lasts for 1/2 hour to 45 minutes? Then for whatever reson the cycle will continue and complete! This just started 6 months after purchase. Any ideas?
Mar 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
