Question about Poulan Garden
Need diagram for carb connections for Poulan 3000 chainsaw . Not sure where tube going to the front from carb.
    President:
  • 2,220 Answers
She is a bit long of tooth.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/ac4577f51a69e10688256bfc0013b59b?OpenDocument
Go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is a Poulan thread with a dozen or so references to this very saw. Join, post your question someone will be happy to answer. If need be they can take a photo of an existing configuration. HTH
Lou
Posted on Feb 03, 2010
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan wild thing 4018. Just replaced the main frame. Had to take apart the whole saw almost. Now the saw will crank but runs at very high speed for a few seconds and then quits. I can goose...
Make sure youmhave connected the primer hoses correctly, the shorter of the two connections on the back of the primer ( suction ) goes to the carb, this pulls fuel from the carb, the longer connection dumps fuel back to the tank, if you removed the cylinder end cap, you need to re seal this to the cylinder with instant gasket, also make sure the air tube between the cylinder and carb is correctly seated.
Jun 29, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Primer bulb which one goes to carb long or short doesnt seem to matter wont go have spark changed carb
I just got a poulan pro wild 2375 but all the fuel lines were rotted and disconected. I know one line runs from the bulb back to the tank and one comes from the tank to the carb but I do not know weather it goes to the top fitting on the carb or the bottom I have to fittings at the carb and there close together any help would be appreciated thanks chuck
Jun 17, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I have a small poulan micro chainsaw with a walbro wa19
I am going to close this. We can continue to converse as we have.
I present you with these parting gifts (look at the 1800 and 2000s):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Just in case
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Good Luck.
Lou
Feb 25, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a Poulan 2000 chainsaw. I changed to sparkplug, clean thoroughly including carborador. after cleaning the chainsaw started and than stopped. It won't start again.
If this saw has a primer make sure lines are connected properly. Check for the wire going to stop switch is not pinched and grounding out. If carb. was disassembled be sure that gaskets and diaphragms are in the right order. Diaphragm with 2 flapper valve should be closest to carb body and diaphragm with metal disk should be installed after gasket is installed against carb body. I am assuming that saw was running before this cleaning. If not remove muffler and look for vertical scratches on piston this would indicate a scored piston.
Jan 15, 2010 | Poulan 1630 16" Chain Saw
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
245 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
