Minolta coppier 3000 has an error code c0500 and
Minolta 3000 has an error code c0500 and will not reset
  • 1,326 Answers
The error code is saying that there is a problem with the fuser section. Did you have a power surg resently? If so you may be able to reset it. If not you may have a blown fuser lamp or thermal fuse or the thirmister. You may have to have it fixed before it resets.. The reset botton is on the main controler on the back of the copier
Posted on Feb 03, 2010
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; There are two way to reset, please do it again; remove back panel,find the master board ( PWB-A) press S 1 ( that's a micro switch)on the main board, the another way to reset is jump PJ29 ( that's a pair of pins) need to jump together, turn on power, about 5 seconds later unjumper, the screen will rewd " initialize complete" then press OK. machine will go back to normal.
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Oct 13, 2008 | Minolta DiALTA Di250 All-In-One Laser...
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
Machine give a coade c0500
The error code C0500 deals with the fixing unit temperature. I could be a blown fixing lamp or thermal fuse or thirmister. You did not give the model number, so I can not tell you how to reset the error code. Good Luck
Nov 02, 2013 | Minolta Office Equipment & Supplies
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
211 people viewed this question
k24674
jasbo
jasbo
