Question about HP Office Equipment & Supplies
I have aHP-4315 all-in-one printer that I can't get off Fax, it won't print from PC but is fine by hand. HELP
    President:
  • HP Master
  • 990 Answers
Hello sir ; Try one reset may be it work,turn switch off ,UNPLUG the power cord , wait for one minute plug in and turn the power on, it should OK.
Posted on Feb 03, 2010
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315 All-in-one I am a Mac user and I cannot do duplex printing or two sided printing
Mac uses a generic driver for all printers. have you verified that duplex printing is check under the printer options?
System Prefs -> Print & Fax -> select the printer, Options and supplies -> driver.
NOTE: if it says print using "Generic postscript driver" you will need to install the manufacturer driver for the printer to get the option to turn on the duplex printing.
May 23, 2011 | HP OfficeJet 4315 All-In-One InkJet...
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
How to set up my 4315 all in one from fax tp printer?
The printer is in FAX mode. Press the fax button that is on right hand side of the display to enable print mode.
Regards
Riztech
Feb 23, 2010 | HP Officejet 4315 All-in-One Printer
I can fax using my printer - donot know how to
sorry I botherd you - I did not have the phone line in corrctly
when I figured it out the fax worked fine
Oct 02, 2009 | HP Office Equipment & Supplies
My HP all in one printer stays in the fax mode
install product software and then send command through it
Jan 11, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Faxing
Please send the procedure, how to fax from HP officeJet 4315. Amartya
Dec 05, 2007 | HP Officejet 4315 All-in-One Printer
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
