Question about HP ScanJet 4100C Flatbed Scanner
All the other features work - copying and printing but the scanner won't work. it says no device is detected. I just used it a couple of weeks ago...
    President:
  • HP Master
  • 2,022 Answers
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Scanning
Make sure the the scanner software is properly installed , you can check it under device manager, because if the scanner driver is not installed it wont really work..
Hope that helps........
Sep 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X6170 All-In-One... Problem
Hi there, for the replacement cost of this unit... i suggest it is time to upgrade to a new device.
regards
Graeme
Mar 07, 2008 | Lexmark X6170 All-In-One InkJet Printer
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Scanner doesn't work
You most probably need to install/re-install the printer/scanner software and scanner manager.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#DriversAndSoftware
Above please find your canon drivers, download these and install as Administrator...also make sure you install the scanner driver as well as the printer driver...also you need a Scan manager too..
If you have installed the scanner before you need to remove it from device manager, by removing the drivers. Once that's done, unplug the printer. Then reboot,.(If you have a CD/DVD that came with the unit, you can and should use this, else download the files from the link given) Then install the new software now do NOT connect the device, only connect when/if asked, or at the end of the install and after a reboot, then, plug in the printer/scanner.
It should be detected and install itself, it may ask for drivers if so, show it where they are, and it should proceed and you should now be able to scan and print, now you must use a scanning program, and or the interface that came with the unit, Canon Scanmanager, however, if installed correctly you can also scan into Mspaint, Word, Publisher etc. but there are many free scan manager programs on the 'net. a good one is Vuescan, http://www.hamrick.com/ now the beauty of this program is that is doesn't require any "Drivers" as it has it's own, so as long as the scanner physically works, then this program will scan with it.
Another is Freekapture ,http://www.freewarefiles.com/FreeKapture_program_32165.html
This uses TWAIN drivers, that should install at the same time.
http://www.ehow.com/how_2006169_troubleshoot-scanner-printer.html
http://www.tutorialsweb.com/computers/printers-scanners/Tools-to-troubleshooting-printer-scanner-problems.htm
Above are a couple of DIY sites to help also.
Nov 08, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Scanner has stopped functioning
ou need clean install . disconnect scanner remove all software in the add/remove area and go to device manger and remove scanner form list. then install software first,rebot, before installing scanner.should work then and for technical support contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP ScanJet 4100C Flatbed Scanner Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
