1997 Jeep Wrangler Logo
Posted on Feb 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How does the belt go on a 1997 jeep wrangler 4.0
How does the serpintine
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
  • Posted on Feb 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
0
Helped
44047
Points
268
Here is a link for the routing of you Wrangler 4.0
www.fixya.com/cars/t2969864-image_put_drive_belt
Hope that helps.
Serpintine belt routing
Here is a link showing you the routing as well as how to do it and the tools you need.
http://www.getahelmet.com/jeeps/maint/belt/
1997 jeep wrangler
It would if there are 2 belts or more present. If it's a one belt setup it has one tensioner. Are you having trouble replacing a belt. Most auto parts stores will print you a belt diagram free of charge. Hope this helps. Chris
2helpful
CHANGING SERPINTINE BELT "98 WANGLER
Somewhere in the world there may be a specification for that but in reality, just make the pulley through bolt tight (without being and animal on it). The long jack bolt gets tightened first. There, you check belt deflection. You should have about one inch or slightly less deflection in the center of the longest run of the belt. After getting it to that point, lock it and tighten the pulley. Run it for a few minutes and then drive it. If the belt squeals, loosen the adjustment and give it a few more turns. Do not over-tighten it. A loose belt will be noisy. An overtightened one can destroy component bearings.
5helpful
How do i replace serpentine belt on 1997 jeep wrangler
Adjustment is made by loosening the power steering pump. There is a transverse long bolt (jack bolt) right under the pump that is used for adjustment.
97 Jeep Wrangler 4.0 with AC & Power Steering. Need belt diagram!
Belt goes over power steering pump,under idler on left,over AC compressor,over alternator,over fan (with back of belt ) over crank pulley then over water pump (back of belt) then back to p/s pump. Routing is counterclockwise.
5helpful
Need route for 97 jeep 2.5 w/ac serpentine belt
1997 JEEP WRANGLER - L4 2.5L 150ci GAS FI N P
Belt Routing Diagram Multiple Accessory, w/A.C.
More details in DAYCO Catalog
I hope help you woth this (remember rated this help).
7helpful
Do you have a image of how to put the drive belt back on a jeep wrangle 1997
* Belt Routing Diagram Multiple Accessory, w/o P.S., w/o A.C.
* Belt Routing Diagram Multiple Accessory, w/P.S., w/o A.C.
* Belt Routing Diagram Multiple Accessory, w/A.C.
1997 JEEP WRANGLER - L6 4.0L 242ci GAS FI N S
* Belt Routing Diagram Multiple Accessory, w/o A.C.
* Belt Routing Diagram Multiple Accessory, w A.C.
For more details, you can visit DAYCO Catalog
I hope help you with this. Good luck (remember rated this help).
Jeep 1997 Wrangler. Gear shifting very hard
synchronizers are going bad a used trans would be cheaper than a rebuild due to the labor involved
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
