Model # MAV5000AWW My washer used to fill but not run throught the cycles without slamming the lid; Now it refuses to run at all. Will this be a simple repair?
    Problem Solver:
  • 6 Answers
Sounds like the safety switch on the lid is faulty.
Posted on Feb 03, 2010
Testimonial: "Thanks for the feedback- all the answers refer to the safety switch on the lid - I think this lady is going to try her hand at fixing!"
    Scholar:
  • 91 Answers
U MIGHT HAVE A BAD LID SWITCH THE MACHINE WILL FILL AN AGITATE, BUT WONT SPIN AN DRAIN
Water is not filling on two of the cycles on my washer model # wf42h5200aw/a2 01
Possible lid switch. My old washer had this issue. 1. Inspect the back right or left corner of the lid. Mine had a L-shaped arm that went up into a hole on the washer and closed the lid switch to start the washing cycles. Over time, mine was misaligned and rusty. 2. Try slamming the lid a couple of times. You may have to spin the dial around back to the beginning of the cycle it stopped on. 3. If that's the problem the switch needs replaced. I opted to unplug my washer from the wall and remove the lift switch and twist the wires together, in effect bypassing the switch.
Feb 04, 2018 | Washing Machines
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Washer wont opperate without lid being slammed or hit in the center of the lid. also wont which cycles without manually turning the knob. and just runs constantly on rinse wont switch to other cycles
Hello Mr. Robertson. With your computer go to 'Sears Parts' and search for your make & model. This site will provide the complete technical service manual including parts ID & pricing. Disconnect the AC power & hoses(prepare to catch the water spill from the hoses), get your tool box,(correcting the lid sensor switch position or replacing it, making a note on the color coded wiring of the controller) and spend the whole day disassembling, confirming what parts you need, gittin em, replacing em, puttin it back together, and savin the money to celebrate.
Sep 01, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
