Question about Durabrand STS92 System
Only works when playing a DVD.
I bought the new Durabrand STS92 yesterday for a present. We have hooked it up entirely and can't seem to get the TV to work on it at all. IT does play his DVD nicely though. Can you help?
  • IdidIT Feb 25, 2008
    Thank you NemOn, I will try that! Thanks for your help. :-)
  • 25 Answers
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Posted on Feb 24, 2008
Can a durabrand dvd home theater system,model #sts96 be used on tv for surround system
I have a sts92 system and run the tv sound through it for surround sound. My Tv has an AV out option, so I ran component cable from the AV out on the TV to the AV in on the sts92. When watching TV, turn on the theater system and set the function to AV in.
Feb 24, 2009 | Durabrand STS92 System
Unable to connect STS 96 to HDTV for hometheater experience
I had the same problem and then found out that it is not a receiver that will allow auxilary equip. It is only good for the DVD player.
Sep 12, 2008 | Durabrand STS92 System
I can't listen mp3 music discs on Durabrand STS92 System
Ask where you bought it,quite often,they will know the answers
Jul 15, 2008 | Durabrand STS92 System
STS96
you must send the audio signal ...from telle to SS
SO....audio OUT of your tv
then .......audio IN to your S.Sound,using AV cables.
Jul 07, 2008 | Durabrand STS92 System
Hook up
red to red, white to white, s video to s video, composite to composite...dude what are you trying to do?
May 25, 2008 | Durabrand STS92 System
How Do I Hook This Thing Up?!?
See what audio outputs your tv has. See if your HTS has matching inputs. If it does connect them with the proper cable(s). Connecting to the tv should cause your HTS to work with anything you are watching on the tv.
May 15, 2008 | Durabrand STS92 System
Problem hooking up my system to the T.V.
check the back of you tv and see if it has the audio out plugs. if it does the you plug the white and red audio cables into the audio (in) on the dvd player and the audio (out) on your tv. then press function on your dvd player until the light on a/v comes on.
Jan 04, 2008 | Durabrand STS92 System
The instructions are very poor
You probably hooked it up wrong. Make sure you hooked up the right speakers to the corresponding jacks, and make sure that your video input jack isn't bad on your tv, or that u have all the av cords going from the output jacks in the dvd palyer, and they lead up to the input jacks on your tv. If the problem still exists, then call customer service, or try a different tv.
Nov 04, 2007 | Durabrand STS92 System
Durabrand STS92 System Logo
122 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
