Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
My Sony Bravia KDL-40V4100 JUMPS TO STANDBY MODE WHEN TURNED ON AND BLINKS CONTINOUSLY FOR 13 TIMES, STOPS FOR ABOUT 2 SECONDS AND REPEATS CONTINOUSLY. NO PICTURES OR AUDIO PRODUCED. DOES NOT RESPOND TO THE REMOTE WHILE ON THIS STANDBY. PLEASE HELP ME. THANKS.
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ....If this helped you (or not) then please rate, thank you!My Sony Bravia KDL-40V4100 JUMPS TO STANDBY MODE - 3c91ad5.jpg
Posted on Feb 03, 2010
Sony bravia kdl-40v4100 . The standby light is flashing red 2 times an television and there is no picture or sound . Relay dls1u an power supply board is clicking on/off .
Two blinks denotes an over-current protection. If you wish to get more details about the blinking codes to Sony TVs, check this site. Details are there. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 19, 2013 | Sony BRAVIA KDL-40V3000 Television
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Jul 09, 2012 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Red standby light go on when I turn on mt Sony bravia
set should have a blink or error code of some type if set does not work--count red and or any other lights blink sequence---3 blinks, 5 blinks etc.
May 14, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
Sony kdl-40w3000 does not turn on. Standby light blinks 13 times. What is the problem
sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
May 04, 2010 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Sep 03, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When turning on the screen comes on for 2 seconds, then red blinking light flashes 13 times and repeats flashing.
Standard blinking codes for Bravia sets for US only goes to 10 blinks which points to faulty or short circuited components inside whereas the Australian range of KDL's goes to 13 blinks of the LED which points to a faulty balancer and must be taken into a service department.
Aug 02, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
782 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
