Question about Brother IntelliFAX 2800 Laser Fax
I have a brother 2850 that is printing very lightly particaularly on the right hand side. It was asking to change the toner so i did that.replacing the toner didnt help the problem. I replace the drum for the first time late last year as the old one lasted for ages. It was working fine then just started printing faintly
  • Brother Master
  • 1,684 Answers
The problem you are having a most likely caused by a dirty corona wire. We have a page on our web site at: http://www.ccl-la.com/Brother_corona.htm that shows how to clean the corona wire and get back to printing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Feb 03, 2010
Testimonial: "thanks mate that has helped a fair bit might give it another couple of goes"
Brother 5370 toner light stays on continuously
if you take the toner cart out and look on the right hand side of it, you will notice a little round window, this window lines up with a sensor inside the printer which looks to this window to reflect back off the toner inside (toner still available)
When the toner gets low enough the sensor does not get a signal back and reports that its out of toner hence the red light.....here's the trick.... if you put a small piece of BLACK tape over the window your printer will continue to print until it completely runs out of toner (several 100 more pages)
Jul 12, 2011 | Brother HL-5370DWT Laser Printer
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
Toner light is on and it wont print
The toner light being on solid means that the toner cartridge is empty.
You will need to replace it with a new one.
When replacing the cartridge, please remember to seperate the toner and the drum, DO NOT THROW OUT THE DRUM.
If you have already changed the toner cartridge with a new one, then you will want to reset the toner cartridge.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 07, 2010 | Brother HL-2170W Laser Printer
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
I have a Brother mfc-8440. It prints light on the
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Greg
Aug 02, 2009 | Office Equipment & Supplies
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
My laser color 9420
Sometimes when toner starts to get low prints will faed or not print on sides. Make sure the printer is on a very level surface. Remove the toners and shake lightly left to right and reinstall.
Aug 09, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother IntelliFAX 2800 Laser Fax Logo
239 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
