Question about Refrigerators
The fridge side coils keep freezing????? And the fridge does not shut off. I put the temp from 38 to 42 and the fridge just keeps running even when I put in a higher temp. Help
  • 52 Answers
Sounds like the internal thermostat is broken.
Posted on Feb 04, 2010
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
I have a GE refrigerator model# GSS22KGMD that keeps freezing the water coil inside behind the crisper. What is the solution to this?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Frigidaire refrigerator side by side is freezing drinks.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
