I just bought a Dell XPS desktop. I bought the Canon MX700. I am trying to install the software but I keep getting a message that says "an error occurred while files were being copied". I can go no further in the installation problem. This is before I even plug in the USB cable per instructions from Canon
-   I have the same problem and cannot install the MX700's drivers on Vista 32 bit. I have tried the software on disc, from the canon website and with the USB cable connected and disconnected. Every time I get the same error message: "an error occured while files were being copied"-   markrbowles
I had this problem just a few minutes ago. The way to get through this is to plug in the USB cable *before* you begin the installation. When Windows detects a device and ask for drivers you need to click cancel for each device (printer, fax, scanner, etc) that it prompts for.
Run the installation disc or file as normal with the USB cable plugged in and it should work. It worked for me.
-info
Windows Vista SP1
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
What does 6A80 mean? I JUST got the printer, set it up, loaded the ink cartridges and now that...
(More)
What does 6A80 mean? I JUST got the printer, set it up, loaded the ink cartridges and now that message.
The paper feed source defaults to "Paper Feed Switch" under "Quality and Media"...
(More)
The paper feed source defaults to "Paper Feed Switch" under "Quality and Media" Tab but it always wants to feed from rear tray even when empty and closed. It did not work this way originally! Is there a way to make it default to front tray without having to set manually on every print?
states "Error" Paper output slot - paper is jammed, clear paper and press OK" no...
(More)
states "Error" Paper output slot - paper is jammed, clear paper and press OK" no paper jam in sight. no paper in machine - any ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
