Question about Gateway MX3560 Notebook
Suddenly my wireless will not stay connected. I get online and in less then five mins. , as I try to go to a different website, nothing happens. Using firefox, will show loading then go to server timed out. Select repair from the wireless connection on task bar, it does it's thing then 5-7 mins. later starts all over. No new additives to laptop. Worked fine for about 10 months.
  • 360 Answers
Go into your "router" configuration under wireless, change the channel it operates on. It is possible some new electronic in your house or neighbor is causing signal interference on that channel causing you to drop your connection periodically.
Posted on Feb 03, 2010
My pond pump keeps stopping and starting
THIS COULD BE THAT THE THERMAL SAFETY SWITCH IS DOING THIS INDICATING A MOTOR IS OVERHEATING , MOST TIMES THEY START CYCLING THIS WAY MEANS A CLOGGED OR DEBRIS FOULED PUMP IMPELLER OR DRIVE SHAFT , ALSO CAN BE MOTOR BEARINGS/BUSHINGS HAVE RUSTED UP , THIS IS A VERY COMMON THING TO HAPPEN IN A MOTOR THAT STAYS OUTSIDE
Jul 28, 2012 | Hozelock Garden
My AMD Athlon(tm) X2 Dual-Core QL-64 by Gateway has wireless network problems. When on wireless, there are lag spikes (meaning it suddenly stops working) every five seconds for around one second each time...
"under the same modem" .. you mean connected to the same router?
if you are using an external USB modem, try a different cable -and keep it short. I can't think right now of any clear causes of this problem other than a bad USB (or too long) cable (which can cause exactly this problem).
possibilities.. could be a cordless phone, cellular, wireless mouse/headphones/controller, bluetooth .. many of these devices connect with their receiver regularly and use almost identical fequencies which interfere.
Doubt it is a network conflict -where someone else has the same IP address. You could try setting a manual IP address too..
good luck!
Aug 31, 2009 | Gateway Computers & Internet
I have signal to my wireless router, but can't get internet
Go into Device Manager uninstall it then click scan for hardware changes. It should pick it up and reinstall it.
The router may have some corrupt info regarding your device in its routing table. Resetting it to defaults might fix it but of course you have to then set it up again.
A less painful way to make it think you have a different device is to change to MAC for your card. Go to the properites of your network connection , go to configure > advanced and in the list you should see network address or locally administered address. Just put in your MAC but change the last 2 digits to something else . The router will assume it is a new device , give it a new IP and hopefully let you surf. Good luck, let me know if you have any problems.
Mar 04, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Wi fi conection interupted
Try switching your wireless router to channel 1.
Jan 10, 2009 | Nintendo Wii Console
Router problem
try to disable any firewall you have, disable windows firewall if its enable and try to lower your Internet Security or use default if set to custom.
Nov 24, 2008 | 3Com OfficeConnect ISDN Lan Modem Router
Trouble with wireless card
Something has gone wrong with your internet home connection--obviously nothing is the matter with your wireless connectivity hardware. You should reconfigure your home wireless connection. Follow the directions in Vista or XP help to set up a new home wireless connection. There are various ways to do this, such as through a router. If you have a home wireless router, be sure to set it for WEP incryption, or your neighbors will be able to get on your internet free.
Apr 24, 2008 | CMB T43 750 Notebook
Open Questions:
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
