Question about Dishwashers
Start Button Doesn't Respond
Wash and Start Buttons suddenly don't respond. (so it doesn't run) Only "Heavy Wash" and "Normal Wash" buttons respond and light up, but START doesn't. How might I fix?
  • lmmayers Feb 03, 2010
    Very helpful
  • 1,284 Answers
Hi, i think the control panel board is kind of faulty in the sense that it is having a partial contact problem with needs to be fixed by merely servicing the control panel board immediately before it affects the remaining buttons.
So you need to call in a dishwasher technician to come and service it which won't really cost much.
Take care
Posted on Feb 03, 2010
Kenmore Dishwasher locked up
Sounds like the washer CPU is defective, have it diagnosed by a local repair technician.
Jul 28, 2017 | Dishwashers
Mouse buttons spontaneously click themselves
I'm afraid that keyboards and mice don't like tea much at all. You can pick up keyboards and mice cheap enough and to be honest they are just not worth repairing. Even a tin of Servisol Video 40, which you can spray on the contacts to clean them will cost you as much as a mouse would!
Mar 12, 2017 | Logitech Cordless Mice 910001822 M510...
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Mune shows up suddenly at anytime, side menu button doesn't respond
had the same problem, did a software update and it fine now.
you can update at site for your tv.
Nov 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hi, My Samsung DVD player remote would not respond when power button pushed on. When DVD power turned on Manually and DVD loaded the remote would not respond to the play, arrow buttons eirther?? My LG...
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Jul 24, 2011 | Televison & Video
The clean light is blinking and no other buttons respond. it is a new control pannel that i just put in the only button that respons is the start\restart but it will just beep
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 18, 2011 | GE GLD4600NCS Built-in Dishwasher
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
