Question about Refrigerators
Ice Maker installation
I have a kenmore model 1068648682 Refrigrator that is ice maker ready. I tried to buy the icemaker for it and it is no longer available. I bought a universal one and it fits perfectly but the connector is a molex and the one for the kenmore needs to be round. I decided to wire it direct to the fast-on terminals behind the back plate of the freezer in place of the round connector wires. It has 4 wires wh, black, green, yellow. White is neutral, black 120v, green ground, and yellow goes to the water valve. I hooked it all up and it doesn't turn on the water valve. I took my multimeter and measured across the water valve terminals and there is 22vac there. The wire is brown and the other side white. The yellow wire from the ice maker is connected where the brown wire was on the factory connector. I can't figure where the 22 vac is coming from. I completely disconnected the ice maker and found that there is 22vac on the water valve solenoid all the time. I do not have the drawings for the refrigerator and I can't solve this problem. Can you help here?
Bernie
  • 770 Answers
The im will only fill when the fingers are at the 12 o;clock position TO cycle your IM ...remove the cover and insert a jumper wire in the T and H holes once you hear a faint click or after 15 sec remove the jumper the im will continue to rotate when it hits (the fingers) the 12 o'clock spot the fill valve is energize for 7 sec then the finger come to rest and stop at the 2 o'clcok position..Let me know if you need more info
Posted on Feb 22, 2008
The icemaker has stopped making ice and the reset function no longer works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your ice maker has a control board, which I suspect is bad. This happens.
You did not provide a refrigerator model number which is located on a label on the inside liner wall of your fresh food section, so I do not know what you have.
I have a friend who called Sears Home Services for his ice maker. Sears charge him $440.00.
I have customer, same ice maker and problem. I charged him, $35.00 for the same ice maker and $30.00 to install.
Depending on the ice maker you may be able to install it yourself.
I need your refrigerator model number to help you.
Peter
Nov 30, 2015 | Refrigerators
Where is ice-detecting sensor located in the bottom freezer refrigerator? No ice/water in door, only in freezer (Kenmore)?
On the side of the icemaker, there is a wire bale or arm that is pushed up by the accumulating ice that shuts off the icemaker.
Oct 01, 2014 | Kenmore Refrigerators
Ice Maker No Longer Working
The icemaker contains an electric motor. You might have drowned it.
Nov 13, 2013 | Kenmore Refrigerators
My icemaker stopped working but the water on the door still works what can the problem be model number 106.51552104
02fd7a9b-9a65-43a6-ae76-6bf68d211304.jpgThanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore Refrigerators
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Oct 15, 2012 | Kenmore Refrigerators
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Remove door and icemaker from bottom freezer model 59673914200 -- icemaker wont turn
The ice maker switch had come unattached due to excess ice buildup, and frozen to the ice pack. The ice in the ice maker had also frozen into a solid block due to not being able to rotate. After removing the drawer trays and protecting the frozen food, turning off the refridgerator, I used a hair drier to melt and remove the ice from the ice maker, gave it time to dry out, -- No gears wer stripped,- the ice maker now works normally.
Aug 23, 2009 | Kenmore Refrigerators
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
