Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
I have a 110,000btu reddy heater. it was running poorly so i changed the air filters and the fuel filter. now it will not fire up. it is not getting any fuel to the nozle. I took the nozle out thinking it was clogged but it wasn't. Heater will run for a few seconds but since it doesn't flame it shuts off. Any ideas?
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
Reddy heater getting fule,air&fire runs 30 sconds cuts off does not light
Things that can cause this symptom
A dirty fuel nozzle
a dirty photo cell / an inproperly positioned photocell or defective photocell
also cracked fuel hoses
a dirty fuel filter.
a clogged air filter.
Here is a service manual that will help you:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
Read pages 7 - 9 first.
Troubleshooting begins on page 10
Also note that spark plug type models are in section B of the manual that starts on page 25
Thanks for choosing FixYa,
Kelly
Jan 18, 2011 | Reddy Heating & Cooling
My heater is a reddy heater 165,000btu. when i plug it up it will ignite, it will get a flame for about ten seconds and it shutdown. i recently replaced the ignitor because it broke and replace the fuel...
I would definitely stop burning off road diesel as it is dirty.Remove the top section of the heater and clean the fire eye with windex and a terry cloth rag, and run K1 kerosene it burns so much cleaner. Also make sure that fuel is not an issuecheck fuel filter,fuel lines and don't forget the screen in behind the nozzle.
Dec 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
I have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
Feb 25, 2009 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Not getting fuel after air and fuel filter maintenance.
If the maintenance procedure included anything that required you to dis-assemble the air pump then you must simply re-set the pump pressure in order for fuel to be pumped into the combustion chamber. . It's an easy procedure. Instructions for setting the pump pressure
Feb 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater runs then stops
it's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
WONT FIRE
have you cleaned the air inlets? I have a older (1970's) reddy heater, occasionally it starts getting smokey or not firing at all. I open up where the air filter is and clean out the chamber with carb cleaner; gets the old girl firing up nice again.
Jan 07, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
286 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
