Question about Palm TX Handheld
My Palm TX will not connect with my computer (Toshiba Laptop) in order to hotsync it.
  • 47 Answers
Make sure to update palm desktop and check if there is anything wrong with the cable.
Posted on Feb 13, 2010
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
My computer that I sync my Palm TX to was "wiped" clean. What steps would I need to take to be able to resync my Palm TX to the computer and not loose everything I have stored on my Palm TX?
Palm Desktop and HotSync won't destroy the data on your device if you have a fresh copy that doesn't have your data backed up. That said, however, look for free utilities that will back up your TX's data to an SD card should HotSync wipe your TX as well.
Jul 09, 2010 | Palm TX Handheld
Hi I can hotsync with cable but not wi fi.It is connecting to router but I cannot access web pages . has been working fine on other routers but not this one.I am using palm TX
Sounds like your net work or security key isn't right for that wifi network.
If you can do basic net things but just not sync then it could be that you need to put in the ip# for the computer that you are hotsyncing to so hotsync can find it.
Mar 16, 2010 | Palm TX Handheld
Bought TX but have no desktop software cd
HI,
Yes if you go to palm.com you will find a section for support. You can download everything you need there to get your PDA up and running. Once you have the software installed on your computer you will want to go in and enter all your information like names and addresses in your contact section. Once you have that all done you connect the PDA to the computer by using the usb cord and then hit HotSync. You can go back later and update any of your infomation right in the PDA itself. Best wishes. Let me know if you need any other help with this.
Aug 11, 2009 | Palm TX Handheld
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
Onscreen status bar
Check the files on the Palm. If you see these two files (or either of them)
AppSlipRotate.prc and StatusBarLib.prc
delete the files and do another Hotsync.
They shouldn't be there - they were needed for the T3, so going from a Zire to a TX shouldn't bring them in - but possibly they were on the Palm already or something.
Aug 15, 2008 | Palm TX Handheld
Trouble syncronizing palm TX
If you look on your handheld, tap the Hotsync icon once.
This will tell you the last time your Palm was synced.
Also if you hold your mouse over the Hotsync icon on your computer in the bottom right hand corner, this will tell you a last Hot sync date.
See if the two dates/times match up.
You can do a search on your computer for a "hotsynclog" file, this will give you a detailed list of all the processes that occurred during your sync. I would see if there are any errors listed there.
Also, you may want to make sure the Palm names match up with what you have on your Palm and the computer. When you click Hotsync on the Palm once, a name should appear in the upper right-hand corner. This name should also appear in the upper right-hand side when you upen Palm Desktop. There will be a white box with a name showing and an arrow pointing downwards. Make sure the two are the same as well and see if your information appears then.
Jan 04, 2008 | Palm TX Handheld
Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Aug 09, 2007 | Palm TX Handheld
Palm TX Handheld Logo
76 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
