Question about Philips FW748P Shelf System
Cassette player won't move / play. - Philips FW748P Shelf System
I have a GPX model CAS337B v 1902-01 cassette player with am/fm radio. When I play the cassette, there is no sound. What to do?
First check if the tape is moving during playback. If it is not there could be something wrong with the mechanism, such as a drive belt being off. If it is moving. Then it could be that a tiny leaf switch has become broken or bent cutting the sound off. Other issues include a faulty switch that controls the switching from the radio to tape. Could be just dirt in the switch. Or the pre-amp failure of the cassette player.
Jun 24, 2018 | GPX Audio Players & Recorders
I have a C-736G Radio/cassette player. The cassette player is not operable. It sounds as if a motor is running when play is activated. However, the cassette tape does not move.Is there a Drive belt?
Yes, they ALL operate with drive belts, which can break, or become stretched. Check that the spool holders move freely, before going into the mechanism.
Dec 10, 2017 | The Audio Players & Recorders
DVD+R won't run on Sanyo DVW-6100
you need to burn the video on a memorex DVD-R disc and then it will play
Jan 20, 2013 | Sanyo DVW-6100 DVD Player/Video Cassette...
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Philips FW748P Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
