My CD/DVD Drive just stopped working!?!
LITE-ON DVDRW SHW-160p6s - Just decided to stop working! What can I do? Please help.
    Scholar:
  • 64 Answers
Is the Drive getting detected in computer.. second did u try going to BIOS and check if it is detected there.. if not then open the computer.. and remove the cables from the Cd/DVD rom and then reinsert them back again.. this should pretty much fix ur problem.. if not then follow the steps below
  1. Click Start My CD/DVD Drive just stopped working!?! - vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in thePrograms list.
    securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
let me know if this was useful regards, guru
Posted on May 05, 2010
I have a problem w/ my Lite On SHW-160P6S DVD RW Dual Layer Burner which won't read any DVD or CD. Also, The door to the unit won't open unless you insert a pin in the little hole on the front of the unit...
You will have to open the unit. To be honest, it's a good idea to buy a new one as I had to change to belt and my drive started smoking when I turned my computer on.
Dec 15, 2010 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
What is the comparable drive for lite-on dvdrw drive SHW-160P6S?
IMHO this Lite-On model,
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4893211&csid=_21
Except it is faster, will read, and burn dual layer disks, and also has LightScribe Technology.
(LightScribe Technology is from HP. You have to use HP disks, (CD or DVD) that are made for LightScribe Technology)
This is the specifications of the Lite-On SHW-160P6S for you to compare against,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1740403&CatId=482
This is information about HP's LightScribe Technology,
http://en.wikipedia.org/wiki/LightScribe
Regards,
joecoolvette
Nov 09, 2010 | Computers & Internet
Says I dont have a dvd burner and I have this one installed.. lite-on DVDRW SHW-160P6S..I can't burn a cd...any help? Sorry for the dumb question you guys!
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Nov 23, 2009 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
How can i get free software for my dvdrw recordrer
The dive has to be vista compatable Where did you get the driver?
Aug 02, 2009 | Computers & Internet
Light_On dvdrw SHW-160p6s working properly but doesn't read anyth
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 15, 2009 | Lite On Beige&Black16X Double Layer DVD RW...
Error Message 'F:\ setup.exe is not a valid win32 application'
I uninstalled nitro. nitro for some reason blocks dvd roms from loading, and give a win 32 mesg.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Lite-on DVDRW SHW 160P6S door won't open on Gateway computer
do you know if adobe photoshop element 4 is compartible with windo Vista?
Nov 21, 2008 | Computers & Internet
Won't read any disc
Could be dirty lens. I'd almost bet bad run of CD-r's though. Does the drive recognize finished cd's? If so it the CDr's.
Mar 25, 2008 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
