Question about Maytag Neptune MDE5500AY Electric Dryer
The Neptune has been taking forever to dry - Maytag Neptune MDE5500AY Electric Dryer
  • 254 Answers
When a dryer takes along time to dry you have a venting problem,, icant telll u if lint is clogged up inside the unit,, or lint is inside you venting, or if lint is cloggged up inside you vent piping through the hose,,, this is common if you have a long vent distance before it exits the house, or possibly the vent is kinked and your dryer is pushed back to far.....
to check undo the venting to back of the dryer and run a load of clothes with no venting hooked up if this drys faster than u know that where your blockage is occuring......
A lil trick also check outside when running you should feel air blowing
also use a leaf blower from inside put in hole of ducting andd blow that line out clean it out hope this helps feel free to leeave me a testimonal leetting me know how things went ...k take care good day
Posted on Feb 03, 2010
I dont know why my neptune dryer takes forever to dry a load of clothes..Appox hours
Check to see if the vent hose is clogged, this will cause the dryer to work longer as there is no air flow.
Dec 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Neptune mde 9700 dryer heats inconsistently. more times than not it take forever to dry a load nomatter what the size
you have either a thermistor at fault of the heating element isnt operating properly
Aug 21, 2009 | Maytag Dryers
Dryer wont dry
do you have the dryer set on high heat,did you clean out the dryer lint shut,hose and exhaust?mike
Apr 20, 2009 | Dryers
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeze noise, do not dry and drop water from the bottom
Replace: a110f97.jpg
These get loose and rattle make it take fifty forevers to dry the clothes. To get to it you must remove the front. Start here:
Dec 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
91 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
