Question about GN Netcom GN 9120 Professional Headset
Hello there, any chance you know how Do I adjust the microphone volume?
  • 3 Answers
I want to transfer images from my mobile to computer
Posted on Feb 03, 2010
My microphone isent working on my laptop i plug a mic in and nuthen can be picked up
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 22, 2011 | Thomson M140 Microphone
I cannot get my microphone to work
Click VOICE
That should be it.
Feb 19, 2011 | Toshiba (P000257700) Microphone
I have a new toshiba laptop and I want to know how to turn on the internal microphone
Click VOICE
That should be it.
Feb 18, 2011 | Toshiba (P000257700) Microphone
My microphone on Presario F762NR stopped working i did troubleshooting and it did not find any problem! maybe it is turned off somewhere and i don't know where!
Click VOICE
That should be it.
Feb 18, 2011 | Compaq PC Microphone (Black or Beige)...
My computer will not see or hear sound from my microphone but i know it works
Click VOICE
That should be it.
Feb 17, 2011 | Labtec Verse-514 Consumer Microphone
My microphone on my laptop does not work i checked everything test it nd cnt hear my voice..?
Click VOICE
That should be it.
Feb 16, 2011 | Toshiba (P000257700) Microphone
Computer does not recognise my microphone, so i can't use skype to call people. i know the microphone works, i've had this problem before and i eventually got the computer to recognise the microphone - but...
Click VOICE
That should be it.
Feb 16, 2011 | Audio Players & Recorders
Hello i have a toshiba l305 laptop and can't get the internal mic to work with any program that uses it
The Microphone might not be working, as it may not be enabled.
However, you may enable the Microphone manually by performing the below steps:
For Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. 4) Click the OK button. 5) Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
For Windows Vista:
1) Right click Speaker near Clock - Recording Devices - right click in box - check 2) Show Disconnected Devices and Show Disabled Devices - check your mic - highlight them and then on lower right properties. 3) Make sure the proper one is enabled and check other settings - on Levels tab make sure MUTE is unchecked and APPLY / OK changes.
For Windows 7:
1) Right click on the volume icon in the system tray and then click “Recording devices”. 2) Right click on the blank place in the popped up window and then select “Show Disabled Devices” and “Show Disconnected Devices”. 3) Right click on Microphone and then click “Enable”. 4) Highlight the microphone and then choose “Set as Default Device”. 5) Click Apply. 6) Select Microphone and click on Properties. 7) Click on Levels tab. The default Microphone Boost is set to 0, increase it.
Hope this helps.
Jun 23, 2010 | Computers & Internet
When i put my hand over the mircophone it makes a sqeeking noise and when i try use adcuity to do my lrics it says error check input
1. The sound that you are hearing when you put your hand over the microphone is just feedback. Try adjusting the microphone input volume down a little and this should help reduce or eliminate this feedback sound. The reason that it happens is because by putting your hand over the microphone, you arr changing the characteristics of the mic's picup as toyr hand helps with reverberation and echo, both of which increase the chance of feedback.
2. I am afraid i don't know the software called adcuity. Please could you let me know the software author and which version it is and i will try to help.
Thanks
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Others are unable to hear me when I do video chat with my dell inspirion mini.My volume is on maximum and I am able to hear them perfectly.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello, all you need to adjust the setting and see.
1. Click "Start"-> "All Programs" --> "Accessories" -->"Entertainment" --> "Volume Control"
2. In the "Volume Control" window that pops up:
3. When you click option then properties then select microphone and wave and line in .
4. Be sure to unpick the box if mute is selected.
Also check your microphone locally on your laptop.
You must hear yourself when you talk in the microphone
Ok try it and let me know
Regards
Uttam
Jan 16, 2010 | Dell Inspiron Mini 10v Netbook Computer
GN Netcom GN 9120 Professional Headset Logo
324 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
