Question about Dell Dimension 9100 PC Desktop
Looking for what kind of processor upgrade
I have a dimension 9100 with OX8582 mobo. i want to know if there are any processor upgrades i can make, and what hd will also jive with it.
  • Dell Master
  • 12,061 Answers
Well it seems you can go up to at least a 3.6GHZ processor. It is socket 775, so any Processor that will fit will in all likelihood work fine. As for the hard drive well I like 7200RPM 8MB Cache 3GB/sec SATA drive. or similar spec, & truthfully one brand is as good as another... But if forced to say.. well Seagate.
Also if you want a fast machine RAM as MUCH as you can put onboard and afford.
I have found a manual here for you. http://support.dell.com/support/edocs/systems/dim9100/en/D86630LRs.pdf
Posted on Feb 03, 2010
Testimonial: "Thank you for your fast response. Your advice is helpful and greatly appreciated. Nick"
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
May 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4300 PC Processor upgrade
if the sci36-r13 is the stock mobo that came with that pc it isnt worth upgrading
pentium 4's use the LGA-775 socket this is compatible with all pentiums and core 2's (not includeing core i7), so you could put in a core 2 quad if you wanted to but it would not make much difference to performance because your motherboard would not be able to handle some of the fetures
your ram would also reduce preformance
if you wanted to upgrade that computer you would have to replace everything but maybe the case
Oct 12, 2009 | Dell Computers & Internet
Processor
First, what kind of upgrade do you expect to do? Many motherboards will not accept a different processor. That being said, you can use a small flat tipped screwdriver between the heat sink and processor. There isn't much room, but very gentle prying all around should do it. You may heat it up a bit with a blow dryer to soften the heat sink compound that hardens with age. You can't harm it with the temperature of the air from a hair dryer.
Mar 11, 2009 | Dell Dimension™ B110 PC Desktop
Upgrade
Upgrade RAM to 4GB if not already done. www.crucial.com
Upgrade Video card www.newegg.com
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
Dell Dimension 4100 Mobo upgrade to a P4 based system
Well the two would not be compatible cause one is a P3 and the next is a P4 two completely different socket types so it wouldn't work but what u can do is buy a new motherboard if u want to upgrade to a P4...thats the only thing that is recommended from such a devices cause an upgrade wouldn't be possible to do .
Nov 22, 2007 | Dell (2336V) Motherboard
Cpu upgrade dell dimension 5100
Hi, according to the Dell website you have a LGA775 socket on your motherboard. Therefore, you can only buy processors that fit into this socket. Here is a list of some offered by Intel that will work: Celeron D 325 2.53 GHz Celeron D 330 2.66 GHz Celeron D 335 2.8 GHz Celeron D 340 2.93 GHz Pentium4 520 2.8 GHz Pentium4 530 3.0 GHz Pentium4 540 3.2GHz Pentium4 550 3.4 GHz Pentium4 560 3.6 GHz Pentium4 570 3.8 GHz The processors that won't work are the ones that are not compatible with this socket. Everytime you look up a cpu it will tell you which socket it is designed for. To buy a cpu you will need to decide: The brand you want. The speed of the cpu that you want. Extras i.e. Hyperthreading, etc. How much you are willing to pay for it. Then you can narrow your search as you stick within your limits. Let me know if you have more questions. Good Luck
Sep 30, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 9100 PC Desktop Logo
136 people viewed this question
Alun Cox
