Question about Gateway MX8711 Notebook
I installed a new hard drive, after reinstalling the operating system it installs up to the point that it has to restart. once it is off it stays off. when i turn it on it says it could not finish because it shut down unexpectedly.
    Problem Solver:
  • 5 Answers
Hi. I don't know if you solved this problem yet, but I thought I might mention that if you are installing windows from a retail disk, you need to install the sata driver when setup ask if you need to install a third party driver. It has to be downloaded and unzipped to a floppy. I used a USB floppy drive for my wifes Gateway M465E and setup continued flawlessly. Prior to doing that I was about to throw it against the wall. Just thought I would mention this solution.
Posted on Apr 29, 2010
  • Gateway Master
  • 12,061 Answers
Reformat and try all again, sometimes takes a few times...
Posted on Feb 03, 2010
Reinstalling operating system from disk
you will need a full windows install disk. You can go to your bios (different computer make/models require different key press at startup to get there) and just select your cd rom to be the primary. Once selected, restart with the install disk loaded and it should immediately attempt to install windows.
Jun 05, 2013 | CTL Travel Master NB5600 (CTLTMNB5600) PC...
Hard drive failure
Try booting to safe mode. Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safemode and hit enter.
If it doesn't gets in, then you would need to do a start up repair.
Look for the operating system installation disc and insert it. Restart the computer and let it run the repair.
If it's not fixed, then you can try doing an operating system reinstallation. If it doesn't work, then I suggest you buy a new hard drive.
David
May 09, 2013 | Computers & Internet
How to change the hard drive that contains the operational system in an Acer EasyStore H341 server?
Transfer an Operating System to a New Hard Drive
When replacing an old hard drive, a process known as cloning is the easiest and most thorough method for transferring data between the old and new hard drives.
A cloning utility takes a snapshot of your current hard drive and then re-creates that snapshot on your new hard drive.
The process clones everything, including the operating system, installed applications, settings and personal files.
Create a system restore disk so that you can return your system to its previous condition if an error occurs.
You can use a backup and restore utility provided with your operating system, or find one for free or for purchase on the Internet.
Many cloning utilities can also create system restore disks.
Shut down the computer and remove power.
Physically install the new hard drive.
Restore power and boot up the computer.
Ensure that your operating system recognizes that the new hard drive has been installed.
Pick the cloning utility that works best for you. (See Below for some options.)
http://www.easeus.com/disk-copy
http://www.clonezilla.org/
http://www.runtime.org/driveimage-xml.htm
All freeware
http://www.acronis.com/homecomputing/products/trueimage
http://www.symantec.com/norton/ghost
Purchase
Base your decision on your operating system and the cost and complexity of the utility.
Install and launch the cloning utility on your old hard drive.
Follow the instructions included with the cloning utility.
Keep the old hard drive as a backup, or reformat it for additional storage space.
Cloning a Notebook Hard Drive
Pick the cloning utility that best fits your needs. (See Above for some options.)
Base your decision on your operating system, the cost and complexity of the utility, and whether the utility can clone notebook hard drives using bootable media, such as CD-ROMs, DVD-ROMs or flash drives.
Keep the old drive as a backup in case the new hard drive fails.
or
Copy an OS to Another Hard Drive
Copying an OS or operating system to another hard drive can serve several functions.
Some simply want to move their current operating environment to a new PC, while others are replacing an old system hard drive with a newer one and want to avoid the hassle of updating and reinstalling.
The process of copying your operating system to another hard drive is a very easy one, in fact, and can be accomplished by anyone with nothing more than some software and some time.
Install Acronis True Image and launch it from its installation icon.
A link is provided below for the Acronis free 15-day trial.
http://www.acronis.com/homecomputing/download/trueimage/
http://www.feyrer.de/g4u/
Support free software or g4u WILL die!
http://www.macrium.com/reflectfree.asp
Macrium has a free also pay options
Click the "Utilities" button from the left menu bar.
Click the "Clone Disk" button from the right pane of the main program window.
This will cause a dialog box to appear.
Click the "Next" button on the bottom-right corner of the dialog box.
Select the disk with the operating system you wish to copy from the drive list and click the "Next" button.
This will begin an examination of your hard disk that will finish in a few minutes.
Select the destination disk from the hard drive list and click the "Next" button.
Choose the "As-is" option for how you would like to handle your partitions.
This option merely lets you decide whether to keep all partitions on the drive or copy just the data onto one blank partition on the new drive.
Click the "Finish" button, and Acronis will prompt you that your system needs to be restarted to begin the cloning process.
The restart will happen automatically when you click the "Finish" button.
Allow the computer to restart, and Acronis will launch prior to the operating system and begin the cloning procedure.
This process may take several minutes to several hours, depending on the size of the operating system and whether there are any installed applications.
Restart you computer once again after Acronis has completed the cloning procedure.
The software will notify you when the cloning has finished.
Boot into your operating system and use your new operating system installation as normal. You may now remove your old operating system drive or format it as you desire.
Hope this helps.
Nov 24, 2012 | Computers & Internet
I lost my cd and need to reinstall it on my new computer so it can work
1. Remove the hard drive, from new PCs, and replace with hard drives from old PCs. Then turn it on.
2. After the computer is on, install the motherboard drivers, and restart.
3. After the driver install process is complete, turn off the PC,
then plug the new hard drive.
So, the hard drive from old PC is a master, and the hard drive from the new PC is a slave.
Sep 22, 2011 | Computers & Internet
How do I erase my hard drive on a IBM T30 and reload the operating system and drivers.
Get an install disk for the operating system you wish to install (Make sure your computer is able to handle that operating system first), then put the disk in and boot to the disk. If your computer is not set up to boot to disk first then you will have to go into the BIOS, usually F2 of F12 on boot (whatever says press to enter setup), then change the boot settings from there.
Once you are inside the installer for that Operating System, it will give you an option to erase the hard drive you are wanting to install the operating system on, and restart new. Just so you are aware, this will reformat and ERASE EVERYTHING on that hard drive, so make sure that you have anything you want saved backed up somewhere else.
Once that is done, continue installing the operating system and then your hard drive will be erased, and the operating system will be reinstalled.
If you were just looking to erase a hard drive, then you can go to my computer, then right-click the hard drive you want to erase, then click format. THIS WILL ERASE EVERYTHING!
Hope this helps!
Mar 23, 2011 | IBM ThinkPad T30 2366 Notebook
My Macbook computer will not start up once it gets to the light blue screen it has a file/ folder with a question mark
It sounds like your system has corrupted. Put your instal disk in. Start your mac up and hold down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay. Then run the disk utility check drive and then run the repair permissions. You can then try restarting, if it works then you are back up and running again. If it does not you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents you MUST use the preserve users instal which will come up as an option. Do not reformat the hard drive as this will wipe all your information.
If you have been running time machine as your backup operation you could instal a totally clean system and then select the time machine backup once the new system has been laid down using the migration utility in the utilities folder within the applications folder.
If your hard drive does not show up the hard drive is probably a goner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Dec 04, 2010 | Computers & Internet
How to format my computer
if you mean, format the hard drive and install your operating system again, if you use Windows, insert the Windows CD to your CD or DVD drive, restart the computer, then tap F12 a few times while the computer is restarting. Once you are on the One Time Boot Menu, select CD/DVD and press Enter. Pay attention on the screen and press Enter or any other keys when prompted to boot to the CD. Then just follow the prompt to install Windows and you will be given an option to reformat your hard drive and reinstall Windows. CAUTION: This will delete all data on the hard drive so be sure to save a backup before you try to reformat the drive.
Oct 04, 2010 | Computers & Internet
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
Convert to raid 1 after Vista install
Install at least 2 more hard-drives, and configure them to use RAID.
Then, copy/move all your data-files from "My Documents" onto the new drive-set. The point here is to have "backup" for your files, not for the Operating System files (which can be re-installed from CD/DVD).
Your "programs" can stay on the "current" disk-drive.
Sep 10, 2009 | Intel DP45SG Motherboard
Dell media direct won't work
Here is the steps,
1.Turn on your computer.
2.Insert the reinstallation media (Dell Media Direct CD/DVD) into the CD/DVD drive, then restart the computer.
3. press F12 when the bios page comes up and then select CD/DVD drive from the boot menu.
"Option 1" from the menu if you wish to use all of the hard drive for you operating system installation. This is the most common selection and how is your computer was originally shipped to you, unless you specified an operating system partition size at the time you ordered you computer.
"Option 2" to designate a size for your operating system and have a data partition. This allows you to specify a size for the operating system partittion, leaving the remainder, of the hard drive configured as a "data" partition ("D")
4. Once you have prepared the drive and you have returned to the main recovery menu, remove the installation media and replace it with you operating system reinstallation media. Select the option to reboot your computer. If your computer does not automatically start the media, press <F12> to access the boot menu and select the Cd/DVD boot option.
5.Install your operating system, select the Primary partition when prompted. If you have two hard drives, select the primary partition on the same disk where hte media direct partition resides. Once the OS is installed and the necessary drivers are installed you can begin the reinstallation of the dell mediaDirect software.
Good Luck,
Austin
Feb 12, 2009 | IBM ThinkPad T30 2366 Notebook
Gateway MX8711 Notebook Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
