Question about Dell Inspiron 1501 Notebook
My screen goes black.
I will be on the laptop working and the screen will go black.
  • 712 Answers
It may be due to OS problem or your HDD is going bad.
So what i would recommend is if you have a old HDD laying around, use it and try reinstalling your OS on it. If it works then your HDD is probably bad so purchase a new one.
Posted on Feb 03, 2010
Black screen external monitor works fine
Replace the screen as the external monitor is OK.
Apr 14, 2014 | Computers & Internet
Black screen when switched on
Okay, does that laptop post to bios first? Example: You see the logo of the company before it goes to a black screen.
Also, do you see a blinking underscore in the top left hand corner?
Dec 09, 2012 | Computers & Internet
On my advent roma 2000 laptop, randomly the screen went black when i turn it on but it comes on at the start for 2 seconds then goes off..? what do i do
its overheating,check whether your fan is working, otherwise open it and clean it out, do not use a blower, the spinning fan can overcharge your motherboard and blow it
Oct 23, 2012 | Advent Computers & Internet
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
After boots the screen goes black, works 4 2 secon...
Check your settings on the CMOS... try using RGB + Analog as your display
May 20, 2010 | Toshiba Satellite A215-S5837 Notebook
Screen Black but Working
It goes black because it went into shutdown due to fault in the inverter circuits, check the 4 transistors in the inverter circuits for shorts, http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 14, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Screen gone black
Sounds like the screen inverter may be going out. The only real way to check it is replace it or take it to a shop and have them test it.
Jul 04, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
