Question about Panasonic Viera TH-50PX80U Plasma TV
Panasonic Plasma "zoomed in"
My new 50" Panasonic plasma is "zoomed" in to the point where it is cutting off anything on the outer edges of the screen. The format function does not help. I'm using an HDMI cable. Any ideas how to "zoom" this out so I can see the out lying areas (scores/scroll bars on ESPN foor example)?
premtech
  • 934 Answers
SOURCE: Overzoomed
Weav,
Reset the unit by using the "Reset" function located in the customer's setup menu. Using the remote control, press the "Menu" button, then "Setup", "About", And "Reset".
Bill
Posted on Nov 05, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
  • 45 Answers
SOURCE: Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Posted on Mar 25, 2008
  • 4 Answers
SOURCE: panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Posted on Dec 30, 2008
SOURCE: i have only the cable and hdmi hook into my
Using your input key on the remote should switch you to the other modes. If you cannot access any HDMI or other input labels, go to your menu, and into the Input Labeling menu (under settings) and make sure you have all the inputs you require enabled. Its possible you (or an out of the box error) put these other inputs offline, which is why you aren't able to access your media from HDMI. If all inputs are enabled, and labeled, double check all the HDMI inputs on the unit. Plug what you are using with HDMI into each port, having the power on and sending information to the television. In some rare cases, I've seen that it doesn't allow access to the HDMI without it providing some source information.
Hope that helps.
Posted on May 08, 2009
Tip
No recompression Cut/Join Panasonic SD900 AVCHD to Plasma TV TC-P50S30 for...
No conversion Split/Join SD900 MTS and Stream and Play on TC-P50S30 1080p Plasma TV on Mac <br /><br />I have a <b>Panasonic HDC-SD900</b> camcorder, which is an excellent compact camera, offering features that few of its rivals can match. It features 1920 x 1080 60p MPEG-4 AVC/H.264 Full HD video. And I would like using my new TV - Panasonic VIERA TC-P50S30 50-Inch 1080p Plasma HDTV for displaying these recorded 1080P MTS videos. And the TV can directly stream/put or <b><a href="http://www.aunsoft.com/final-mate-mac/">display Raw Panasonic SD900 AVCHD MTS to Plasma TV</a></b> for enjoyment via HDMI. Because of rocking of the lens and some pause in the process of recording, some extra clips will come out, so before <b>enjoy Panasonic Videos with Panasonic TC-P50S30 Plasma TV</b>, I want to do simply editing like cutting off unwanted or unimportant parts and then merge or <b>join the cut several meaningful MTS files into One Big MTS file</b> with no re-encoding and without losing any quality. <br /><br />When I search <b>AVCHD MTS Cutter/Joiner</b>, I get batch of programs, like TSmuxer, TSsniper. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new software for me named <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Mate for Mac</a></b> - an efficient Panasonic HDCam software. It offers the one fastest way to join MTS files into big one for further playing on Panasonic TC-P50S30 Plasma HDTV. Then I download and try it. And I had succeed with the solit and stitch the .mts files and the output one big .mts files without recompression. <br /><br />Now I will show you a fast way to cut off native Panasonic HDC-SD900 1080p MTS clips, and then join them into one file without conversion for streaming and playing on Panasonic VIERA TC-P50S30 50-Inch 1080p Plasma HDTV on Mac OS X Snow Leopard. <br /><br />Step 1. <b>Capture native MTS from Panasonic HDC-SD900 to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b>Mac SD900 AVCHD cutter/joiner without recompression</b>, and drag the .mts files already backup all mts recordings from Panasonic SD900 to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. Create a Movie for <b>combine SD900 AVCHD MTS 1080p footage lossless output</b>. <br />Click the drop-down button for the Add movie icon and choose lossless output, please drag and drop camcorder .mts clips you would like to merge to this Movie. You can select all files by clicking Ctrl +A, and then drag them to the timeline to join all these MTS files into one movie easily.Thus, one lossless output Movie is ready for <b><a href="http://www.aunsoft.com/final-mate-mac/">merging SD900 MTS files without conversion</a></b>. <br /><br />Step 3. <b>Cut off unwanted parts from 1080p MTS for Panasonic TC-P50S30 1080p Plasma HDTV</b>. <br />From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /><br />Step 4. <b>Join and export SD900 MTS with no loss of quality for Panasonic TC-P50S30 Plasma HDTV on Mac</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner for Panasonic Plasma HDTV will start lossless mts output - merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://sony-mts-converter.com/2011/06/no-conversion-splitjoin-sd900-mts-to-play-on-tc-p50s30-1080p-plasma-tv/">Mac joining SD900 1080P MTS files for Plasma HDTV</a></b>. <br /> <br />Hope you enjoy the simple merging Panasonic SD900 1080P MTS process with Aunsoft Final Mate for Mac to <b>stream re-encoding 1080p mts for Panasonic TC-P50S30 1080P Plasma HDTV</b>. <br /><br />Tips: With this Panasonic HDCam Manage Software - Final Mate for Mac, also can convert SD900 1080P MTS to AIC MOV or ProRes MOV and edit on iMovie,Final Cut Expres s and Final Cut Pro.
on Jun 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
The picture is too large, almost as if it is on zoom, so the edges of the picture are cut off. How do I fix it?
check and see if you have a zoom button on the TV remote
If your hooked to a cable box call the provider because some of the cable boxes have a setting that will cause this issue
Dec 04, 2010 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
DVD picture is pink
check that all leads are pushed in
Nov 29, 2009 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Line in queens new york- have a panasonic plasma th-50pz800u craked front glass- still shows- looking to replace- anyone with contact numbers or web sites to replace glass. Thanks
try auction or surplus electronic sites buy a broken plasma screen tv unit ask the seller if the outer glass is good most like they only sell it if the inner plasma glass is broken try that sometimes this is the easiest way unless you want to pay full price and parts site..i do have a 42" front glass thats good but i dont know if this fits the 50". hope this help
Jun 24, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Plasma cutter started cutting at an angle even when held perfectly perpendicular. New consumables were put on, same amperage, same air pressure. I'm stumped!
did you put all new consumables in ,sounds like there is still old one there.make sure nozzel is put back together right.I have worked on welders and plasmas for years,the torch head is very tempermental.
Mar 01, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Overzoomed
Weav,
Bill
Nov 05, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-50PX80U Plasma TV Logo
452 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
