Question about Soleus Dehumidifiers
Everything seems to work, the filter is clean, nothing seems to be blocked, but it doesn't collect water
  • 1,284 Answers
Hi, from your explanation above concerning your dehumidifier not collecting water, check if the operating fan is ok because some dehumidifier have a frost guard switch (round device attached to the evaporator coils). If this frost guard opens circuit, it will stop the compressor from running at all. A ohm meter can be used to test the frost guard switch.
You can visit this site to get more information especially on the diagram.....
http://www.applianceaid.com/dehumidifier.html
Posted on Feb 03, 2010
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
My dehumidifier no longer works. It started with running almost contantly without much water output. Now it just runs without any output. I only run it spring summer and fall. It is located in the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 31, 2011 | Haier DM30EAL Dehumidifier
Dehumidifier does not collect moisture. cleaned the filter and still doesn't work. fan works fine.
heatman101
Jun 22, 2011 | Kenmore Dehumidifiers
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
Jun 18, 2011 | Maytag Dehumidifiers
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
The fan is on but no water is collecting
Check to see if compressor is operating.
Apr 08, 2010 | Haier 45-Pint Dehumidifier
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
Dehumidifier not collecting water
most probable cause of a dehumidifier not collecting water when it appears to run fine otherwise is a dirty heat exchanger. It is unlikely that a huge spread in the time a unit works is caused by failure of the compressor of loss of refrigerant. On the other hand, people use their units in very varied conditions of dust in the environment with expected short to long operating times before failure. Here's how to fix this problem in two steps.
Step 1: Determine if your compressor and refrigerant sealed unit is operational
Step 2: If Step one is negative, dispose of the unit - specialized equipment is required to repair or recharge a compressor. If step one is positive, then clean the heat exchanger.
This site did not allow me to post the full instructions because they exceed an unspecified upper limit to message length. What a waste of time. In order to be helpful, please contact me at j_sjohn@hotmail.com and I will email you a file with a complete set of instructions. Cheers.
Jan 02, 2009 | Dehumidifiers
Dehumidifiers Logo
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
