Chances are, lint or some piece of clothing (a sock or handerchief, maybe an iron-on patch came loose) is clogging the drain hose. Remove the drain hose and see if it is clogged. Perhaps, running a straightened-out clothes hanger through the hose will dislodge the obstruction. Also, check the drain from the tub to the hose attachment point. To do this, you will need to remove the inner (perforated) tub from the outer (solid) tub. You see, only the inner tub spins. The water is spun-out by centrifical force and flows from that outer (stationary) tub through a pump, and from there to the drain hose. Good luck.
