Question about Emerson LD195EM8 19 in. LCD TV
I just bought a 19 inch flat tv with the dvd player and pc input. I hooked it up to my computer with the vga cable and it says it doesn't recognize the format. what am I doing wrong?
  • Emerson Master
  • 12,061 Answers
Set the screen resolution, on the PC, to a low initial setting say 800x600 32bit, and also ensure your Video Out is set right either PAL or NTSC depending on what your TV receives. Make sure you have activated dual display "Extend windows desktop to here" under Video Properties, (Right Click Desktop)...and finally plug in to TV, turn on, and THEN boot up.
Posted on Feb 03, 2010
Testimonial: "This was very helpful. Thank you so much!"
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Can I connect the LC19DV22U to my computer to use only as a monitor? And if so, how. I have misplaced the manual.
where did you hooked up the cable at the tv, what component input did you use like HDMI or VGA port? if your pc has the vga output you will use the vga port input of your tv then select in the source PC to get the signal from pc.
Oct 16, 2012 | Sharp LC19DV22U 19 in. LCD Television
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
My neighbor bought a 32"
Unless the tv has a VGA input, or the laptop has a HDMI output, I am afraid you are going through too many conversions to make this work.
Mar 16, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Hook up a Sony VGC RA 840G desktop to a Samsung 46 inch TV
Some TV's don't have a VGA input. S-Video cable is more common. Look on the back of your computer an see if you have an S-Video jack. If you have a TV compatible output on your computer, such as an S-video jack, just take an S-video cable and connect it to your computer and your TV. If you do not, then attach your VGA end of your adapter to your computer and use the RCA, S-video or Component Video cable to attach to your TV. After you've made all the connections, make sure you are on the correct TV video input. Press the input button on your TV or remote until you see your computer's signal.
Apr 11, 2009 | Sony VAIO VGC-RA840G PC Desktop
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Hocking up my computer to a t.v.
Hook The VGA Cord (PC INPUT) into Your Laptop's Hookup Spot
Turn The TV Input to VGA Or PC or Computer and on the Laptop it should show up if you Hit The Function Key + F8
If You Are using A Desktop Hook It To the VGA Out Just Like You Where Hooking Up To A Computer and Turn The INPUT on the TV to VGA or PC or Computer and it should show up just like A Computer Monitor
Hope I Helped
Dec 20, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Emerson LD195EM8 19 in. LCD TV Logo
474 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
