Question about Toshiba Satellite A105-S4004 Notebook
Screen flickers with lines but when i move the screen it stops
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
A nearby device can cause stray magnetic fields that will cause the display to be affected. A problem inside the monitor will cause the display to have problems. If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
ERNZ
Posted on Feb 03, 2010
Dell Inspiron 2350 All-in-One Desktop PC Fault Flickering Touch Screen
It could be 1 of 2 things, either your monitor is going out on you, or your graphics adapter is going bad. Depending on how long ago you purchased it, and from whom, I would contact Dell service to find out if they can return it, or give you any suggestion.
May 19, 2014 | Dell Computers & Internet
Screen has been flickering, does not go black but gets really dark. Sometimes if I tap it or move it is stops. Is my screen going bad?
sounds like a loose connection somewhere. find a local computer repair shop. Often those guys can diagnose a common problem just by glancing at the symptoms. GeekSquad is great but costs lots.
Jan 21, 2013 | HP Pavilion Computers & Internet
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
The display on my laptop has stopped working. All I get is a blank screen. A couple of days before lines appeared on the screen and if you moved the screen it flickered on and off....any ideas?
there is a ribbon connector that runs from the labtop to the screen .... eather it has become loose ro disconnected or the screen has shorted out the first of the two sounds like the problem
Mar 01, 2010 | HP Compaq Presario CQ50-110US Laptop
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
451 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
