Question about Optoma MovieTime DV10 Multimedia Projector
Can't open it
After unscrewing all screws of the projector I still can't open it. How is it done?
  • 27 Answers
Keep trying.try gently prising case with wifes best kitchen knife to see if case is springing against a specific point.
probably more screws to take out, inside lamphouse or hidden
Posted on Feb 26, 2008
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
How do you open a BENQ MP610 projector to replace the light? What tool do you use? Thanks Marty
I just replaced my lamp for the same beamer. Took me a while to figure out how, but if you know how, it is easy. Turn the beamer on its back. In the middle, you will see a black rubber (small), it covers a hole and a screw is in the whole. Pull the small bblack rubber out. Unscrew the screw. A small cover will come loose. And there is the lamp, You have to pull out the power cable, and than only one little screw that mounts the lamp to the inside of the beamer.
It's easy!
Hope you will succeed,
Ojnoka
May 23, 2009 | BenQ MP610 Multimedia Projector
Optoma projector
u need to open the 4 screws on the sides
then there is one screw in the center at the bottom
the u also need to unscrew the nut screws on the vga connector.once done
press the top of the panel near the keypad & the front cover will come off
similar is the procedure for the back cover.
when you try to lift the top cover make sure not be hasty, open slowly s there is a film connector for the keypad that is connected to the main board,take care not to damge it
once you have acess to the main board
loosen 2 screws on the mainboard & then press the outer side of the main board.there is a 100 pin connector that connects the main board to the dlp engine.this is the cause of the problem that you mentioned.this should fix your prob
Feb 09, 2009 | Optoma EP716 Multimedia Projector
Replacement Instructions
Hi
it's a simple switch out, first make sure your set is unplugged, open the panel concealing the lamp, unscrew the door, unscrew the lamp, pull it out straight towards you it is attached like an outlet plug, carefully switch it with the new one be sure not to touch the lens, screw in tightly replace the compartment door then the panel and your done....good luck }:)
Jul 04, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Replacing the lamp in SIM2 ht-200
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
May 28, 2008 | SIM2 HT300 Multimedia Projector
How do you get the bulb out of the Phillips ProScreen 4750?
Hi there
There should be a lamp door at the bottom of the Projector that you have to unscrew before you will be able to take out the lamp.
May 19, 2008 | Philips ProScreen 4750 Impact Multimedia...
LG RD-JT91 PSU problem
Hi there
On the left hand side where all the inputs are located you will see a very small screw , that is most probably what's keeping you from opening it.
Also remember to take off the cover to the front and do this slowly because the translation board's lint is attached to the top cover. Once open you can just unhook it and then you'll be looking for the board with the AC inlet on it.
Apr 12, 2008 | LG RD-JT91 Multimedia Projector
Opening the Sharp XR10-X
There is a screw to open the cover. then see the two or three screws inside for lamp.unscrew the same and pull the lamp out.
May 06, 2007 | Sharp XR-10X Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
57 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
