Question about Phoenix Gold Car Audio & Video
I need the wiring diagram for phoenix gold saphire sa 1.0x
  • 631 Answers
SOURCE: phoenix gold xenon 1200.1
Most of them are NE5532s. There's one NJM13700 also.
Posted on Apr 23, 2008
  • 631 Answers
SOURCE: Phoenix Gold Octane-R 15.0:1
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
Posted on Aug 15, 2008
SOURCE: need to find a manual
You need an owners manual?
Posted on Apr 14, 2009
yungdub
  • 93 Answers
SOURCE: I am looking for a wiring diagram for a PHOENIX
really no need for a diagram, it says where each wire goes on the amp
Posted on Jun 14, 2009
etirbynnor
  • 655 Answers
SOURCE: HOW TO WIRE ONE DVC SUBWOOFER TO A PHOENIX GOLD
Hello matt225281.
Since the Tantrum only lists specifications into a 4ohm load, you need to make sure that the final impedance of your DVC sub is 4ohms or greater. So a sub with either 2ohm or 4ohm voice coils needs to have the coils wired in series with a jumper between the positive of one coil to the negative of the other and the remaining positive and negative to the amp speaker terminals. Paralleling the voice coils will result in a 1ohm or 2ohm load to the amp and it will overheat, go into protection or possibly fail completely.
If your sub has 2ohm voice coils, the load will be 4ohms which allows the amp to produce maximum power. The final impedance with 4ohm voice coils will be 8ohms. The power will be reduced, but the amp will operate without overheating.
Either set of the speaker terminals on the amp can be used. They are connected internally so it doesn't matter which one you use.
Hope this helps.
Posted on Jul 11, 2009
Hi im looking for a phoenix gold xenon x 200.4 amplifier schematic diagram
To request a schematic diagram, contact Phoenix Gold directly.
May 12, 2017 | Phoenix Gold Car Audio & Video
Where do I get the schematic?
the owners manual as well as the wiring diagrams and such can be found here:
http://narbi.free.fr/manuels/Amplis/Phoenix%20gold/M50.pdf
May 08, 2014 | Phoenix Gold Car Audio & Video
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
I have a phoenix gold 600.2 and it keeps blowing my fuse, what do i do?
check you have a good ground connection, make sure all wires are correctly installed and make sure it is not shorting out (ie none of the wires are in contact with one another) failing this will need more details.
May 17, 2010 | Phoenix Gold Xenon-600.1 Car Audio...
Basscube remote knob wire
sloth...
funny seeing this question posted here... I worked at Phoenix Gold for 4 years, and I can help you with your problem.
when the BassCUBE was designed, the engineers didnt realize that a standard phone cable is what we call a "flipped cable", where if you were to lay the cable flat without any twists in it, on one end the connector would be tab up, and the other end would be tab down. on a standard RJ11 plug (the phone plug), the telephone requires that the pinout is as follows:
#1 - Black
#2 - Red
#3 - Green
#4 - Yellow
But the BassCUBE needs a non-flipped cable, which are hard as heck to find... so I will give you the quick easy fix.
You need a 2-line (4-wire) telephone cable that has a black, a red, a green, and a yellow wire in side it, and you will need 4 crimp caps or other way to splice the wires back together. You then need to cut the wire in half, and carefully seperate and strip each wire on each piece of the cable. Call one piece "Part A", and the other piece "Part B". Then you need to splice the cable back together as below.
Part A Part B
Black ------------------> Yellow
Red --------------------> Green
Green -----------------> Red
Yellow ----------------> Black
Once you have done this, and your SURE that your splice is good (not shorted out), then go ahead and plug your modified cable into the BassCUBE and its remote control, power it up, and you should be good to go.
Nov 04, 2008 | Phoenix Gold Tantrum BASSCUBE Car...
Aug 14, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Car Audio & Video Logo
115 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
