Question about ASUS P5LP-LE Motherboard
I need to know how to hook up the cables to the PC . My PC dies and when I started to dimantle it to beef up other computers I found out that one memory stick was bad. so I am trying to put everything back together and plug all the cable back up.
  • soulsurvivor May 11, 2010
    Do you need help with external hook up or internal?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
All the data u need will be there in the motherboard mannual
Posted on Feb 03, 2010
Why does my 96 Lasabre starts then dies
Sounds like your security has set and you will need to hook a computer that is body computer capability to reset the computer and that should help your vehicle start again
Nov 25, 2014 | 1996 Buick LeSabre
89 prelude starts for just a few seconds
Make sure your positive and negative hook ups from both cables to the battery are completely clean, has no corrosion on them, and that they are tight. It sounds like the cables have corrosion on them
Apr 11, 2013 | Honda Prelude Cars & Trucks
Run and them dies
I found a vacuum leak on the carb base gasket by spraying carb cleaner around it. Then it would stay running while spraying. I replaced gasket but it still run and died. I was told to clear all codes in the computer by disconnecting the battery cables from the battery then hook the pos and neg cables together for half an hour. Then I hooked the battery back up and started it up and it ran better than ever. I guess unless you clear the codes the computer reads theres still a problem even though you fixed it.
Feb 06, 2013 | 1988 Dodge Ramcharger
Need to hook up my computer to my amplifer
I used a regular RCA (red, white, and yellow ) cable to stereo. Then found an 3.5mm stereo adapter (red and white are audio), and connected to my speaker output on PC. Even works with phones with YouTube and iPods.
Aug 31, 2012 | Audio Players & Recorders
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
What are some of the things i can do to beef up my gt5220
easy options
(1) buy an external hard drive
(2) up grade memory
(3) run disc clean up- click start, all programs, accessories, system tools, disc clean up.
Run the disc cleanup on drive "c", be careful not to erase compress old files as you can lose some important older docs if you do.
Does this help in any way?
May 03, 2009 | Gateway GT5220 PC Desktop
Car died at light. battery light on. got a jump start car cranks as long as cables hooked up. take cables off car dies. will not stay started.
Thatttttt's alternatorrrrr.
Your alternator charges your battery. No alternator, no battery charge.
Apr 23, 2009 | 1998 GMC Jimmy
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Hp officejet all in one
I assume from your message that you mean you can't print a document from your computer or send and receive faxes. Chances are, you'll have to reinstall the printer, just the same way as when you first bought it and hooked it up to your PC. Also, the operating system on your computer is going to make a difference. For example, if you originally hooked the printer up to a Windows XP computer and now you're hooking it up to a Windows Vista computer, you'll need to install different print drivers.
I don't know if you have the original manuals or disks that came with the printer. If not, a good place to start would be to download the manual from HP.com. That'll at least get you started:
Manuals page
It would be really helpful if you were to post what steps you took to connect your printer to your PC once you got the printer out of storage. Also, how long had it been in storage, are you hooking it up to the same PC or a different PC than before you put it in storage, and are you hooking it up to the PC differently now than before (printer cable vs. USB cable, for example)?
Thanks.
Sep 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Tosiba saterlite A100 pro- how do i dimantle
1. Release the following 10 latches on the switch cover, in that order:
- Six bottom latches (near LCD/ Hinge side)
- Four front latches
2. Remove the speaker cover.
Remove 2 screws holding keyboard in place lift up and
Remove the connector CN11 on main board and keyboard.
The odds of "Repairing" the keyboard are practically nill, I would use an external until a replacement could arrive. LINK
Jun 03, 2008 | Toshiba Satellite A105 Notebook
ASUS P5LP-LE Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
