Question about Rinnai Heating & Cooling
Just installed a used rinnai silent servant 606A
Heater turns off after 5 minutes. Get code 12 in temp box.
hotuna
  • 288 Answers
SOURCE: 606tr rinnai silent server
You are not getting gas for some reason. Check the valve to make sure it is getting power to open the solenoid. It may need to be set to on. If you are getting power to the valve and its not getting gas, check the orifice. Sometimes a spider or other bug will get in there and plug it up. Its a very small hole, so it wont take much to block it.
Posted on Mar 02, 2008
  • 53 Answers
SOURCE: I have a Rinnai 506 silent servant vent free
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Posted on Dec 05, 2009
  • 120 Answers
SOURCE: Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Posted on Jul 30, 2010
SOURCE: My Rinnai 606tr Silent Server continually shuts
I know that this is an old post but i had this same problem and i cant find a single answer to this problem anywhere on the net. Rinnai couldnt even give me an answer (let alone even call me back)
Well I figured it out. If you go onto Rinnai's website, you can download the manual, which has the codes and what they mean. Code 12 means Flame Failure. Still this didnt tell me enough. After taking the thing completely apart twice i finally figured out that the heater itself was perfectly fine.
The gas line was the problem. My gas line has a check valve on it right next to the heater. The check valve was not letting a consistent flow of gas to the heater because the heater was drawing too much gas at times, causing the check valve to start to close because it thought there was a leak (so to speak).
All i did was turn the gas valve behind the heater so that it was closed more (not letting as much gas flow through) so that it wouldnt trip the check valve. the heater now works fine and keeps a consistent temperature with no problems.
Posted on Dec 07, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Problem with the Rinnai RHFE-1004FAP
Hello
There should be a condensation line connected to the flue running into a pump or floor drain.or possibly a internal heater to disapate it.
Beacause the heater reuses the gas there is alot of moisture in natural gas,thay needs to be drained from the flue.
Sounds like this condensate line is either clogged or frozen or both.Yes your going to need to thaw the flue out.Before you do this turn off all gas and electric to the heater,we do not want it to start.
A hair dryer may do the trick,to help thaw the ice off.If you can locate the drain line for the flue and thaw it out and clean it out.Check that all filters are clean and in place before starting up.
Also check outside that nothing is driping onto the flue from the roof or a tree.
I found a link with your owners manual.
Hope ive helped.
http://www.rinnai.us/documentation/downloads/Owners_Manual_1004.pdf
Posted on Dec 14, 2010
Testimonial: "GREAT ANSWER --- used a hair dryer on the outside flue (after it had been in sun a few hours (luckily flue is on south side of house) Started by turned gas/elec off, then chip'd most of ice off, then gave it high heat till water started drip'g out of flue (~2-3 mins), then went back inside and turned gas/elec back on and started heater --after repeating this process a few times (3?) heater stayed on and we had heat !!!! Sorry for not writing sooner.... but want to let you know that we had the 'opportunity' to reapply your solution twice more during last winter - worked great both times !! "
Rinnai 606a manuel
Rinnai 606a manuel Google Search ..goto this link and see if you find your manual
Dec 02, 2016 | Rinnai Heating & Cooling
My 606a rinnai heater flashes 12
According to the Rinnai manual which is here:
https://www.rinnai.us/documentation/downloads/RC-606-48x05(00)_owners_manual_RCE-606TRAII_vent_free.pdf
It looks like that is a "flame failure". They suggest ventilating the room and turning the heater off and on again, I think this might mean the heater was eating all of the oxygen in your room.
Maybe cracking a window a small bit?
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
Silent servant convector vent -free space heater
I would never blow out a gas heater with a compressor... It is too powerful and you could have damaged something inside.
I would get it checked by a gas fitter.
Mar 12, 2013 | Rinnai Toyostove Direct Vent Heater:...
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
My Rinnai 606tr Silent Server continually shuts down and the number 12 appears on the display screen. What's up ?
Jan 05, 2010 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Blinking 12 and I have no manual to indicate what that means.
A 12 code indicates a "Flame Failure" check that the gas valve on the right side of the unit is turned on. If you are using propane have you confirmed that the tank has fuel? You may be able to download the owners manual from the Rinnai website.If not you can contact themat 1-800 621-9419.
This is a great heater and the Rinnai people will be helpful. good luck!
Oct 12, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
962 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
