Question about HP Photosmart 2610xi All-In-One InkJet Printer
Hi I keep getting a message that says "remove and check cartridge on right". After doing that and putting it back in the error message remains. Do I just need to replace the cartridge?
    Master:
  • HP Master
  • 406 Answers
Yes replace the cartridge.
Posted on Feb 03, 2010
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
I've received the error message: "Printer
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Hi, I'm getting an error mesage that says right cartridge incorrect. I took the cartridge out and put it back in , but I'm still getting the error message. It was working fine and then the message appeared
turn the printer on.then remove both the cartridges out.on the cartridges you will see the brown color dotted circuit.clean that circuit with a dry tissue paper.on the lower base of the cartridge you will see the nozzle of the cartridge from where the ink comes out from the cartridge from printing.clean that area also with tissue paper.dont apply too much force on the circuit , the circuit of the cartridge is very delicate so take take care you don't make rashes on the cartridge or nozzle while cleaning the cartridges.clean the circuit of both the cartridges one-by-one. then in the printer where you insert the cartridges,there also you will see the same brown color dotted circuit .clean that circuit also with the dry tissue.take care you don't damage the printer circuit.then after the cleaning is finished,properly insert the cartridges in the printer to their respective positions.then check out the printer display.is it showing the same message or the message is gone.if its showing the same message ,then turn the printer off then ON then check out again if its still the same problem message on display then its confirmed that the right side cartridge in the printer is got faulty.the brown dotted circuit is getting short in the cartridge so the printer is not detecting the cartridge and this error comes on.in this case the cartridge needs to be replaced.this is very common problem and occurs many a times.replacing the cartridge solves the problem if cleaning the circuit does not helps. this will help.please do rate the solution.keep updated for any further assistance if more help required.,thanks.
Apr 29, 2010 | Dell 962 Photo All-In-One InkJet Printer
I have a dell printer with a error code 1102...how do I solve this?
error code 1102
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 08, 2010 | Dell 962 Photo All-In-One InkJet Printer
Getting
Hi there
Jan 14, 2010 | Dell 962 Photo All-In-One InkJet Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Installed new cartridges; keep getting error message
I'd say your using dodgy aftermarket or non HP cartridges, you could put your old ones in and see if message goes away, if having problem when using with Original HP cartridges post back and I'll did deeper for you.
I dont work for HP, I do know printers :-)
Dec 28, 2007 | HP Deskjet 5440 InkJet Photo Printer
HP Photosmart 2610xi All-In-One InkJet Printer Logo
153 people viewed this question
Seeker5211
Seeker5211
