Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
The sandby liht come on and the TV won't. the standby light flashes 9 times
  • marshall Feb 03, 2010
    Yes thank you! i now would like to know where i can get a another G board A1054157A. I looked on the two sites given but they dont have them.
  • 1,476 Answers
Your unit has a problem on the "G" board. The specific problem doesn't matter you would not be able to repair it unless you are an electronic tech. If you are good with your hands and can work a screwdriver you can probably change out the board which would be your best bet. Unplug the unit first from the mains. Remove the back. Looking at the boards locate the "G" board. Sony labels all its boards with big letters starting with "A". Once you find the board remove any wires from their connectors marking each end (male and female) with a number using a majic marker. Remove the board. You can get a replacement at www.partstore.com or www.shopjimmy.com . I do not know the cost but I would guess less than $200. Install the new board. Reassemble the unit making sure everything is correct. Plug in and try. Your unit should be good to go. Let me know how you make out or if you need more information or run into any issues I can help with.
hardrocko
Posted on Feb 03, 2010
When I turn my tv on the green light blinks then it goes to sandby and will not turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 04, 2015 | Televison & Video
My Sony tv won't switch of standby just flashes
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
Feb 17, 2013 | Televison & Video
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Sandby light flashing red/green will not trun on
Hi gm,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
How many times does it blink?
Jan 06, 2011 | Sony FD Trinitron KD-30XS955 30" TV
TV wont turn on, sandby light flashes 7 times.
Any malfunction associated with a flashing stand-by light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Jul 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
