Question about Zenith B32A24Z 32" TV
Parental control locked
We had a electrical power outage and when it was restored a message came on my TV key in the parental control code. I can't because I never keyed in the code before. Is there some type of override for this problem.
  • 492 Answers
Yes there is. You will have to contact the manufacture with the tvs information for the unlock sequence.
Posted on Mar 07, 2008
I want to delete the parental control and have no code number please help many thanks
  1. Open the Parental Locking Settings screen (MENU - SETTINGS - PARENTAL LOCKING). Press OK.
  2. You will be prompted to enter your PIN.
  3. Use the ARROW buttons on your remote control to select TURN OFF LOCKING, and then press the OK button.
  4. Select RESET ALL PARENTAL LOCKS, and then press OK.
  5. Select RESET ALL PARENTAL CONTROLS. Press OK. A message appears asking if you want to reset the 4 digit PIN and stop using parental locks.
  6. Select RESET and press OK.
The set-top box closes the Parental Locking Settings screen and returns to the last channel tuned.
The Parental locking option in the SETTINGS screen shows parental locking as completely turned off (no lock icon in the Parental Controls box).
Apr 04, 2018 | The Video Game Consoles & Games
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I forgot code for parental lock on my RCA F32668 32" tv, please help. Thanks
RCA TV Parental Reset Code: First select parental control from the menu. You will be asked to enter your password. Press and hold the "volume +" and "channel +" buttons on your television (not the remote) for 8 seconds. You will see a message that the parental controls have been unlocked.
How To Unlock Your TV Parental Control Password
Jul 07, 2015 | RCA Televison & Video
A red key on tv screen
The TV is locked. Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
· Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
For more information go to http://electronicshelponline.blogspot.com/
Nov 26, 2013 | Apex Digital AT2702 27" TV
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
Tv is locked, i need a fix
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Oct 01, 2012 | Televison & Video
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Zenith B32A24Z 32" TV Logo
74 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
