Question about Toto Plumbing
Have a toto faucet TEL70AV100 battery keeps running down suppossed to self generate
2 Suggested Answers
Jacky1eye
  • 31 Answers
SOURCE: I am working on a
Sounds like the battery. Make sure shut off valves under sink are in on position as well.
Posted on Apr 22, 2011
Replacing cartridge in toto nexus faucet
Go to their web site for instructions
Sep 11, 2017 | Toto Plumbing
How can I take the top cover off of my toto cross handled faucet? I need to tighten the screw underneath
There are mant different types of Toto Cross handles. The more common handle has a screw in one of the cross stems. If you unscrew and remove it you should have access to that piece. Then you can use a blunt tipped object to apply pressure from the bottom of the handle. Be careful it may be glued on. If that doese'nt work there should be a very small hole on the side of that little cap. Take a paper clip and jently but fermly pry it up and out.
Sep 13, 2014 | Toto Plumbing
I have a 71 sportster 900 that battery keeps running down
try replacing your regulator as the diodes may be stuffed or on way out
Jul 09, 2009 | Harley Davidson FLSTS Heritage Springer...
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
NEON 2004 OFF NO BATTERY
The alternator powers everything when the car is on, Some cars need a battery to complete the circuit. If your not having any other problums with the car you should be good
Apr 04, 2009 | 2004 Dodge Neon
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Mar 13, 2009 | Toto Washlet S400 for Power Gravity...
Plumbing Logo
172 people viewed this question
Top Toto Plumbing Experts
Donni Steen
Tom Chichester
Are you a Toto Plumbing Expert? Answer questions, earn points and help others
