I have brought a new D Link wireless router and I am trying to install it so that I can have my internet phone working. The manual says that I have to reset my router to factory default settings, which I reset it, now I have to coonect my PC to the router using the ethernet cable, if I do this I will lose the internet. What do I do?
  • 360 Answers
You should have 3 basic hardware components, Modem, Router and Computer.
The Modem connects to the Router via an ethernet cable, then your computer connects to the router via a ethernet cable for setup. After setup you can configure the wireless and unplug the ethernet cable (if you have a wireless adapter on your computer).
Now here is where I believe your "no internet" problem is coming from...you have to reboot your modem after connecting it to your router. If your modem has a battery backup, you have to pull the battery out and also unplug it from the wall for a reboot.
Reason for the above is that your modem is only allowed to lease 1 IP Address and it leases it to the MAC Address of a hardware component connected to it as the modem boots up. If you had the modem connected directly to your computer, it leased the IP to your computer's MAC Address.
So, hook everything up right and reboot every device one by one starting with the Modem, then router and then your computer.
After it is all working, setup your wireless and make sure to make it encrypted (secured) so your neighbors can not get free internet off of you. While it is nice to give free internet, they can abuse it and do illegal activities on it and then your ISP thinks it is you doing the illegal stuff. After it is all set up right, then you can unplug the ethernet from router to computer and use your wireless.
Good luck and I hope this helps you out.
Posted on Feb 03, 2010
  • 742 Answers
Once you reset you router to default settings, it will be using dynamic IPs since by default, DHCP will be enabled. If you have an IP phone, then you can immediately get access to the internet and use VOIP services, as your phone provider said. With regards to your PC, you can directly connect it through ethernet cable as usual. If your PC is set to have a dynamic IP, then it is just plug and play. However, if you were using static IPs, then you have to reconfigure your PC to enable DHCP. For Windows XP:
1. Click Start => Settings => Network Connections
2. Under LAN or High-Speed Internet Group, right-click on your LAN (usually named as "Local Area Connection #")
3. Click on Properties
4. Under the General Tab, scroll down to the bottom and locate the item Internet Protocol (TCP/IP). Click on it and then click Properties.
5. In the window that pops up, under the general tab, make sure that you ticked (selected) "Obtain an IP address automatically" and "Obtain DNS Server address automatically.
Try your luck. I hope that helps. For Vista, just locate network and follow similar procedures.
D-Link DIR-615 mobile phone wifi internet connection problems? connect but no internet
What wireless modes are you using? Under Setup/Wireless/Manual.
Try single mode G or mixed G and N?
Channel Width set for Auto 20/40Mhz or try 20Mhz only.
Try setting a manual channel to a open or unused channel.
What security mode are you using? Preferred security is WPA-Personal. WPA2/AES Only. Some WiFi adapters don't support AES, so you might want to try TPIK only or Auto.
What wireless devices do you have connected?
Any cordless house phones?
Any other WiFi routers in the area? Use InSSIDer to find out.
Turn off Short GI, WLAN Partition and Extra Wireless Protection if you have it. Under Advanced/Advanced Wireless.
Sep 17, 2014 | Computers & Internet
My internet has beem on the frits lately since we moved into our new house because our intenet provider switched modems, doing so they said that I'll need reinstall my router towards the new modem in...
What I have here is a manual of your router. You do not need to run the installation cd. Along with this link is a step by step manner on how to reinstall your router. If you do have further question please message me.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Thank you!
Jul 10, 2011 | D-Link DIR-615 Wireless Router
I installed my dir 600 2days ago.. after the configuration its says "successful" but when we were trying to use the wifi,it says in our iphone that there were no internet connection.. so i tried...
Hi danielle,
I see you are connecting a mobile phone using a wireless link in you home.
on the d-link setting make sure that the Network security is turned Off and that the wireless module is turned on the D-link Router to be able to get the signal from your Iphone the network security can only be used on Laptops when turned on but on mobile phones if the netwrok security is turned on mobile phone may have issues connecting to the Router.
I hope this helps.
Have a nice day,
mvincentc
Jun 12, 2011 | D-Link DIR-600 Router
I am trying to add a new mac ip address to my wireless router i started with 1 pc then brought a laptop and a wireless d-link router they work fine i just brought home another pc it has a card put through...
Please follow the steps mentioned below on the Computer where the internet connection is working normally and check if the issue is resolved.
  • Please type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  • Please Use "Admin" as the user name and leave the password blank when the login screen appears.
  • Please click on Wireless, enter the Wireless SSID name (name for the Network) and under Security, select the Security type and type the Security Key.
  • Save the settings and try to connect to Wireless on the Computer having the issue.
  • It will ask for the Security Key, enter the Security Key provided during the Wireless setup.
This should resolve the issue.
If the issue is not resolved, reset the Router to factory settings and then try connecting.
Please try to locate the Reset button near the Ethernet ports and press for 10 seconds.
Good Luck!!!!
Please let me know if you require further assistance.
Thank you for contacting.
Jun 23, 2010 | D-Link SWT DSL-504T ADSL MODEM with 4...
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
D-LINK Wireless G Router WBR-1310
Try changing the channel on your wireless setting or try downgrading your operating system to windows XP.
Jan 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connection
I had the same problem with a TP-Link wireless. I made connection first with the computer hooked to the DSL modem. Brought up a browser and made sure I was on line. Then connected Modem to router and router to computer. There were pop-up messages to let me know when Cable was unplugged and when connected was made again. I then stayed connected, until the electric went off and immediately back on. So had to go through it again to reconnect. Hope this works for you. Thanks
Feb 17, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
