Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Ice maker does not make ice - should the shut off arm move down to fill the ice bucket and then stay up when the bucket is full. Can I manually move the arm down? It is in the up position and I wonder if that is why it won't make ice. The manual says to avoid touching the automoatic shut off arm. What does this mean?
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
catriver
  • 878 Answers
SOURCE: GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Posted on Dec 29, 2007
SOURCE: ice maker sensor arm
the arm is hung up on a srcrew that is on the divider wall to the right of the icemaker pull the arm off the screw. The icemaker is a mechanical one so the arm will not just drop down so put the ice bucket back in and turn the icemaker back in the control panel further problem call customer service for assistance for over the phone help 1 800 222 7820 they will be glad to assist their customers unlike other manufactures.
Posted on Apr 29, 2008
  • 210 Answers
SOURCE: Ice maker not producing ice
What you can try to do is put the ice maker in test mode. Press and hold the ice size button, on the ice maker itself, for 5 seconds. It should cycle through and this could reset it.
Sgt 48
Posted on May 31, 2008
  • 489 Answers
SOURCE: Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Posted on Sep 30, 2008
Kitchenaid icemaker will not shut off when bin is full of ice. Model: KUIS18NNXSo
Is there a wire/bar that goes across the ice bucket? As ice fills the bar raises up and eventually goes high enough to shut the maker off until the level goes down.
You can manually lift the bar up to ~ horizontal until it clicks in place and stays there. That should shut it off until you move it back down. If there is no bar, then I guess there in no way your ice maker knows when it is full and keeps producing. Perhaps the bar was removed, bent or broken off. At least tht is one type of ice maker I'm familiar with. Other types my have different ways to tell the maker it's full.
Mar 12, 2018 | KitchenAid Refrigerators
Ice maker subzero 690 stuck won't make ice because i think the plastic flap that rises when the ice bucket fills is stuck and won't come down to turn on the water
There is a screw sticking out from the right side of the freezer wall that has a grey plastic spacer around it that acts as a stopper for the ice level arm. I have seen the ice level arm get stuck on top of this stopper before somehow. you just have to carefully bend the level arm around it and move it below the grey plastic stopper. If it is not stuck above that but the arm still will not come down, then the only other solution is likely a new icemaker, as the arm is geared internally to the icemaker to rise and fall as the ice is made.
Sep 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
Can you turn the ice maker off like other refrigerator ice makers? I didn't see anyway to turn my ice maker off or do I empty the ice out everytime?
Most ice makers have a control arm that raises and lowers to check for a full condition. It usually raises during the dump cycle and lowers during the fill cyle. If it is unable to lower (because the bin in full) it should shut off the fill cycle. If that function is not working, then if you move that control arm to the fully raised position, it should shut of the fill cycle, until you manually lower it again.
Jun 04, 2011 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Kenmore Ice Maker not dropping ice
Sounds like the arm which determines if ice bucket is full is hanging up on something. Does this arm move up and down freely? If not, you just need to replace the complete ice maker.
Nov 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchenaid superba icemaker
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
Sep 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker
Hello Carol34,
I'd like to help you but you will first have to provide some additonal information. First off, did it ever work? Not sure what you mean when you refer to the 'part that goes down to release ice just stays down".. are you referring to the arm that shuts off ice making when the bucket is full? Please provide this information so that we can get your ice working again..
Thanks
Aug 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker arm issue
If you are a real DIY'er, remove the ice maker from the frig and see if the arm has or had a spring return down or check its position with the cam that operates it as it goes around.
May 29, 2008 | Whirlpool ED2FHEXN Side by Side...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
88 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
