Question about XION (XON-001) ATX Mid-Tower Case
Need update to bios for a compaq 8QSXE1 XP1800 so it will recognize 2 gig of ram. Max it will currently recognize is 1.5 gig
    Genius:
  • 1,027 Answers
Go to the Dell site for the Bios update.
Posted on Feb 05, 2010
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Ram upgrade maximum slots memory
http://www.crucial.com/index.aspx
Go to this web site and follow the steps and it will help you find out what you need to up grade your laptop.
Dec 02, 2013 | Compaq Presario Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Intalled 2 - 2 gig Ram bios is only reading 3.
Hello.
I believe the ram needs to be on seperate channels to work.
Giving you a link to a supprot manual.
Good luck.
http://www.fixya.com/PostAnswer.aspx?thid=3880661
Jan 13, 2010 | Computers & Internet
Want to install 4Gb
memory is a tricky thing you have to make sure that the meory is compatable with your mobo(for instance) my laptop is a acer aspire 3000 it takes pc2700 ddr memory that runs at 333 mhrtz i just upgraded from a 128 and 512 set to 2 gig im running xp home,also xp will only recognizes 2 gig max unless it the 64 bit ver which then will go up to 4 gig and up also vista as well will run up to 4 gig and up usually 64bit ver will recognize 4 or more gig however if you need soem more help id need make model of laptop your running as swell as which ver of windows.happy hunting-z
Jan 30, 2009 | Acer Extensa 4620 Notebook
No display after upgrading RAM
Are you saying that there are only 2 slots for ram or 4, if 4 then you may have a dual channel lap top, in which case you need all of the ram to match, they all have to be the same exact ram.you cant mix and match, also is the bios recent, it sounds like you may need a bios flash if the laptop isn't recent.And there may be a limitation on the amount of ram it takes, I just setup a brand new acer and it only two gig max, see if they offer a bios update
Dec 23, 2008 | Gateway M-6866 15.4" Widescreen Laptop...
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
I have a Compaq Presario, model #: SR2150NX memory problem
To Be pricise ...there is no hardware problem.
The problem can be two.
1.Your computer supports max of 1.5 GB RAM.....For this check with other vendors too.
2.You have to update your BIOS.
If you can provide me the motherboard no and details i can clarify more on it
Jun 02, 2008 | HP Compaq Presario SR2150NX PC Desktop
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
XION (XON-001) ATX Mid-Tower Case Logo
74 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
shuyumeng
shuyumeng
Farokh Merek
Farokh Merek
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
