Question about Kenmore 62602 Electric Dryer
I have a 3 wire dryer and need to convertto a 4
I have a 3 wire dryer and need to convert to a 4 wire
  • 10,865 Answers
To change your dryer cord from a 3-wire to a 4-wire you first need to disconnect the old dryer cord, then disconnect the bonding jumper on your dryer.
The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer's neutral (white wire) terminal and the green ground screw connected to your dryer's frame.
Removing this bonding jumper is an extremely important step when changing from a 3-wire to a 4-wire cord to prevent electrical shocks when touching anything metallic on your dryer.
To connect your new 4-wire cord, connect each wire to the dryer's terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer's frame.
Posted on Feb 03, 2010
  • 506 Answers
A 3 wire dryer is 120Vac and a four wire dryer is 240Vac. If you are not familiar with an electrical panel, call an electrician. This involves removing the current breaker plus another and installing a new 240AC 30 AMP breaker. You will also need to upgrade the wiring and outlet for the unit as well. Your service may not have room to accommodate the new 240Vac breaker and you may need a sub panel installed. I would suggest calling an electrician.
  • 5,911 Answers
The following link explains how to correctly install a 220VAC appliance cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Match the corresponding colors at the terminal block, making sure the Neutral (White) and Ground (Green or Bare Copper) wires are NOT terminated together.
If you have any questions, please post back and let me know. I hope this helps you.
Tip
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
If you have an electric dryer and need to change the style of cord that you have on the dryer on if you just need to install a cord on a new dryer, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
Remember to ALWAYS make sure that all power is disconnected BEFORE beginning your work!!
On the back of your dryer will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look like this.
You will have a red wire, a white wire, and a black wire, on the other end from the plug.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. wire and a couple of crimp rings. Green wire is preferable.
The connection will look something like this.
If you have a 4 wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the dryer. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
This connection will look something like this.
When converting from a 3 wire to a 4 wire you just REMOVE the bonding strap or wire and hook the green wire to the frame. If you are converting from a 4 wire to a 3 wire then you ADD the bonding strap or wire. It gets hooked from the center lug to the frame.
Always make sure that the outlet that you are plugging into is wire correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole 30 amp. circuit breaker. The wiring needs to be a minimum of 10 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new dryer or convert your existing dryer cord. Recheck all your connections before turning the power back on to the dryer.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Apr 06, 2010 | Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
When i convert 3 prong to 4 prong can i double up the white and green grounding wires?
Hi Brandon
Go to the following webpage to see a picture of the 3 to 4 wire conversion
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Apr 17, 2013 | Estate Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I have a 4 prong plug with 4 wires but i have a dryer that only supports 3 wires what do i do
Have an appliance guy convert your plug to a 4 prong. The issue is safety. You need the 4 wires.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Whirlpool LE5795XPNO 3-wire to 4-wire
The following link explains how to convert your dryer from 3-wire to 4-wire:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, or require further assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Whirlpool LER5636P Electric Dryer
Converting gas dryer into electric dryer
i don't think you can convert the gas dryer to an electric dryer.
there are so many issues to consider.
1 the contacts of the timer would be a big problem,
2 the heating element wiring uses big wires where as the existing wires are very small to handle the big current of the heaters.
3 the configuration of extra part that you would have such as the gas solenoids, the ignite r, the flame sensor, etc which electric dryer does not have.
and more....
so bottom line is..... can not convert.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
184 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
